Hello, I decided to make a double MintyBoost, No reason really, just thought it might be cool. Well, it doesn't work. I've measured voltages and here is what I get:
Ground to Pin 1 of USB - 3.2v
to Pin 2 2.2v
to Pin 3 2.2v
This is the voltage readings on both of them so whatever I did wrong, I was consistent. Not sure what else to try. I know this isn't one of the MintyBoost kits so there might not be any way to help. Thanks for looking though.
Tom
Double MintyBoost not working
- Attachments
- MB PCB and Schematic.jpg (154.49 KiB) Viewed 2035 times
- MB Bottom.jpg (128.73 KiB) Viewed 2035 times
- MB Top.jpg (156.46 KiB) Viewed 2035 times
- ifrpilot999
Re: Double MintyBoost not working
Looks like the chip is the LT1302CN8. The MB kit uses the LT1302CN8-5. The "-5" has resistors built in that set the output voltage to 5 volts. Not sure if there are other issues with the PCB, etc.
Thanks ifrpilot999. I've looked through all of the literature and datasheets and still can't find a difference between the CN8 and CN8-5. It's definitely worth a try. I'll see if I can get some samples. Thanks again.
Tom
Tom
- adafruit_support_bill
Hard to reconcile those measurements with the voltage divider in the schematic. Double check your measurements and component values.Ground to Pin 1 of USB - 3.2v
to Pin 2 2.2v
to Pin 3 2.2v
- ifrpilot999
Tom -- Take a look at the datasheet, page 7, top right. "The LT1302-5 incorporates feedback resistors R1 and R2 into the device. Output voltage is set at 5.05V in Burst Mode, dropping to 4.97V in current mode."
Hope this helps. Also, Adadfruit support is the real BANNED master on this chip but usually only supports their kits builds.
Your right. after I posted that I couldn't see a difference I went back and found the part you referenced to. I'm sure the correct chip will clear up my problems. Thanks ifrpilot999.
Tom
Tom
Does your circuit works?
Mopped
Mopped
Hello Tom,
Looking at your new boards there's a ton of usable space, perhaps you could incorporate a wider ground plane for pin 1 and 8 to enhance heatsinking. I hope you managed to find the error, otherwise the layout looks great.
Referencing: http://cds.linear.com/docs/en/datasheet/lt1302.pdf
PGND (Pin 8): Power Ground. Pins 8 and 1 should be connected under the package. In the SO package, pins 1 and 8 are thermally connected to the die. One square inch of PCB copper provides an adequate heat sink for the device.
