I'm an experienced kit builder and put together the Minty Boost kit according to the directions (version 1.1). I have fresh batteries with a measured output of 1.45+ volts each.
Symptoms are the Ipod Shuffle charge light pulses on and off two times and then remains off. What voltages should I check to make sure I put it together correctly.
I do not see any bad traces or solder bridges and all connections are shiny and bright.
Is there a published trouble shooting guide so I can trace the voltage through the minty boost to trouble shoot?
Thanks//Mark
Minty Boost
