Hot Diode
Ideas and questions about MintyBoost kits
shmagoogin77
Posts: 30 Joined: Mon Oct 01, 2007 9:58 pm
Post
by shmagoogin77 » Wed Apr 09, 2008 11:24 am
Im using the old minty boost pcb to power a simple bike light from ladyada's tutorials. When i connect the 2 AAs to the minty boost the diode pins on the underside of the board get very hot. Should i try replacing the diode?
Posts: 12151 Joined: Thu Apr 06, 2006 4:21 pm
Post
by adafruit » Wed Apr 09, 2008 12:38 pm
are you using a schottky diode?
Post
by adafruit » Wed Apr 09, 2008 7:46 pm
well, does it work?
shmagoogin77
Post
by shmagoogin77 » Thu Apr 10, 2008 5:20 pm
sorry i forgot to explain
ok so the diode gets very hot and the output is 0
also the 2 AAs get hot and output aroun 1.5 v
its very strange
Post
by adafruit » Thu Apr 10, 2008 5:53 pm
you should post a picture of your kit it will make it easy to debug the problem
The_Don125
Posts: 373 Joined: Tue Mar 06, 2007 11:51 pm
Post
by The_Don125 » Thu Apr 10, 2008 8:29 pm
Is the diode in the correct way? Sounds like it might be creating a short circuit across the batteries.
shmagoogin77
Post
by shmagoogin77 » Fri Apr 11, 2008 11:23 am
the minty boost had been working fine before
i even had it power my arduino and everything but now the diode gets hot and shorts the batteries
i just got some maxim ic samples for the booster so maybe i could try replacing the chip
Post
by adafruit » Fri Apr 11, 2008 12:07 pm
shmagoogin77
Post
by shmagoogin77 » Sun Apr 13, 2008 12:46 pm
is it possible that i overloaded the current?
i had it powering a standalone arduino along with 5 leds
Post
by adafruit » Sun Apr 13, 2008 8:10 pm
without connection to the arduino, check the output voltage
then verify you're connecting gnd to - and vcc to +
try again?
shmagoogin77
Post
by shmagoogin77 » Mon Apr 14, 2008 9:22 pm
i tested it with the AVR unplugged
im still getting nothing
Post
by adafruit » Mon Apr 14, 2008 9:37 pm
sounds toasted
i would def try a different max756 i run arduino's off of mintyboosts and its just fine
also check
batteries, your multimeter
shmagoogin77
Post
by shmagoogin77 » Mon Apr 14, 2008 11:02 pm
alright
thanks ladyada
side question: with R4 and R5 in the pullup mode will it work with other devices besides the ipod 6thgen or does it vary?
Post
by adafruit » Tue Apr 15, 2008 1:48 am
it -should- work for all ipods and devices
