My Minty-boost lives! Complete and charging and old phone.
Thanks for the help and patience with a newbie.
Ray
Minty-boost USB connector pins 2 and 3 dead
- rccpilot
- adafruit_support_bill
Re: Minty-boost USB connector pins 2 and 3 dead
Congratulations!
- clarkj
Hi Ray!
FWIW, analog meters (i.e., most ones with a needle to indicate the reading) have relatively low "impedance" -- that is, they can load down the circuit that you're trying to measure. Fortunately, digital meters tend to have a much higher impedance. If you're located in the continental U.S., find out of there's a Harbor Freight Tools near you. Watch their ads -- you can often see coupons to get a basic Digital Multi Meter for free with any purchase (sometimes even with no purchase). It's not a great meter, but hey, the price is right, and in my experience, they're good enough for about 95% of the hobbyist uses.
Clark
Clark
- kucher
I too have pins 2 and 3 (to pin 4) almost dead. Only getting 0.09 volts from 2 to 4 and 3 to 4 of the USB pads. I am getting 4.98v across pines 1 and 4. Using fully charged Eneloops producing 2.7v (in two pack) or 5.5v (in 4 pack).
- Attachments
- minty_boost - 3.jpg (120.44 KiB) Viewed 2375 times
- minty_boost - 1.jpg (174.3 KiB) Viewed 2375 times
@kucher -
So the boost circuit is working correctly. If the voltage on pins 2 and 3 is not correct, it is a problem with how you have installed the resistors. Measure the voltage drop across each of the 4 resistors: R1, R2, R3 and R4.I am getting 4.98v across pines 1 and 4
- kucher
hello,
thank you for the quick reply. Please excuse my tardy response.
Here are the readings.
I hope I am doing them correctly:
From + to R1 0.03v 2.75v
R2 0.03v 2.23v
R3 0.03v 2.75
R4 0.03v 2.23v
From - to R1 0.09v 0.0
R2 0.09v 4.99v
R3 0.09v 4.98v
R4 009v 4.98
Thank you for looking into this.
R2 0.03v 2.23v
R3 0.03v 2.75
R4 0.03v 2.23v
R2 0.09v 4.99v
R3 0.09v 4.98v
R4 009v 4.98
That sounds half right - but the other half sounds impossible.
For each resistor, measure the voltage between the two ends of the resistor..
