Solar Minty Boost with Calculator Solar Cells
Ideas and questions about MintyBoost kits
13harwooda
Post by 13harwooda »
I recently bought the minty boost as well as the USB/DC/Solar charger, however I am trying to come up with a solar charging option that will not cost as much as buying a new 6V solar cell. I scavenged four mini solar cells from some old calculators and I would like to try using these, however I am wondering if this would be a reasonable alternative. I know the voltage will be around the correct value (I can boost this by obtaining more of these little solar cells) however I was wondering if the power output would be enough as I know these cells produce very little current
Franklin97355
Re: Solar Minty Boost with Calculator Solar Cells
Post by Franklin97355 »
You have the cells so you need to find their power output to decide if this will work for you.
Return to “MintyBoost”
