I was wondering where you get your solder stencil
from I would like to order a set.
erich81 wrote:Awarru wrote:I am interested too in the boards but the link posted above is for the old board. Has erich81 finished his redesigned PCB's with the .BRD file that works in Batch PCB? If so where are the designs?
I have finished the designs, however I've been waiting till my solder stencil and parts come in to test the top board (I've built the Li-Ion board, and it works/passes all tests)
If you would like me to post the updated files now before testing, I'll do it within the next day or so, when I get a chance.
Thanks.
Edit: I've added the li-ion board, I can't find the signal board eagles, however I have the gerbers that passed BatchPCB's design check, and were run off. I'll attach those here. As stated, the lion board is fine, and I've E-tested the signal board, so it looks good both mechanically and visually. The only problem I have with the design is that where the switches are, the two front pads are missing. (contacts are correct). My solution for this is going to be to use different switches that I can panel mount in the case i'll put it in.
Here are what the gerbers produce, in case you want to know before using (please note on the battery board, I added a spot for a 2 pin JST connector, in case i used a battery that had one. This does not need to be populated if you're soldering your battery on like I did. the 2 pin JST connectors are available at sparkfun.com):
I'll work to redo the main board since I can't find the eagle files, and will post a set when i finish editing.
