atmega help ?
atmega help ?
does anybody know if the atmega 8L8ai will work for the wave bubble i have a lot of these. and if anybody needs one let me know .....
Re: atmega help ?
The Wavebubble website has a hardware design page which says, quote:
"An ATmega88 is used, although an ATmega48 or 168 is pin and function compatible (just with less/more program storage). An ATmega8 is also acceptable although the firmware may need adjustments"
However, I do not know what firmware adjustment might be necessary.
Re: atmega help ?
For one the fuse settings would be different for the ATMEGA8. It also has less space so you may need to cut down/optimise the firmware to fit. Not really worth it when the ATMEGA88 is under $4..
