The operation of transmitters designed to jam or block wireless communications is a violation of the Communications Act of 1934, as amended ("Act"). See 47 U.S.C. Sections 301, 302a, 333. The Act prohibits any person from willfully or maliciously interfering with the radio communications of any station licensed or authorized under the Act or operated by the U.S. government. 47 U.S.C. Section 333. The manufacture, importation, sale or offer for sale, including advertising, of devices designed to block or jam wireless transmissions is prohibited. 47 U.S.C. Section 302a(b). Parties in violation of these provisions may be subject to the penalties set out in 47 U.S.C. Sections 501-510. Fines for a first offense can range as high as $11,000 for each violation or imprisonment for up to one year, and the device used may also be seized and forfeited to the U.S. government.
Hi all, been working on my own wavebubble, and I've got a quick question, hopefully somebody can help.
I've gotten up to the point where I need to run the LED test using the first "burn-fuse" command. I have tested all my power rails, and ensured that the LED lights properly when given 3.3V.
I run the "make burn-fuse" command and the programming appears to be successful, but the LED does not blink. I have already uncommented the proper line in main.c.
Sorry I'm a bit confused. I commented out the line test_led() in the main method of main.c. Then I do it again with that commented, and the LED doesn't blink. Is it normal that avrdude says it is only writing one byte?
