No DC jack
The operation of transmitters designed to jam or block wireless communications is a violation of the Communications Act of 1934, as amended ("Act"). See 47 U.S.C. Sections 301, 302a, 333. The Act prohibits any person from willfully or maliciously interfering with the radio communications of any station licensed or authorized under the Act or operated by the U.S. government. 47 U.S.C. Section 333. The manufacture, importation, sale or offer for sale, including advertising, of devices designed to block or jam wireless transmissions is prohibited. 47 U.S.C. Section 302a(b). Parties in violation of these provisions may be subject to the penalties set out in 47 U.S.C. Sections 501-510. Fines for a first offense can range as high as $11,000 for each violation or imprisonment for up to one year, and the device used may also be seized and forfeited to the U.S. government.
westbrookp1
No DC jack
Post by westbrookp1 »
the project says that we can use the usb as the charger and not use the jack. It says: If you leave out the DC jack, solder the RING pad to the RING-SWITCH pad as the jack connects them internally by default!..... what exactly does this mean and how would i go about doing this?
Chuck
Re: No DC jack
Post by Chuck »
Look on the schematic for the battery board.
See in the top left, the DC power jack?
Notice how the GND is bridged to the trace that goes to the USB jack?
When the power connector is not in the jack -- then the USB ground goes tothe circuit ground.
When you plug in the dc power it breaks that connection and connects the DC power ground to circuit ground.
If you don't install the DC Power Jack you need to make that connection on the circuit board by bridging the USB ground to the circuit ground.
make sense?
westbrookp1
Re: No DC jack
On the three pads that connect the dc jack, Do i connect the two pads that are very close vertically together?
Return to “Wave Bubble”
