I placed an order with barebonespcb.com for the PCB and I ordered MOST of the parts for my wave bubble. I am having problems with two remaining parts and hoped others could help. (Wow what a cost difference a soldermask and silkscreen can make between 4pcb.com and barebonespcb).
The following parts are no longer carried by digikey or require obscene min orders.
CAP CER 1.0UF 50V X5S 0603
IC AVR MCU 8K 20MHZ 5V 32TQFP
IC FREQ SYNTH DUAL 20TSSOP
TRANSISTOR PNP 35V 3A HP SOT223
I replaced the cap with a 25V as recommended elsewhere in this forum and I found the microcontroller on mouser no problem. The last two parts are invading me. If anyone has a source for these could you lead me in the right direction.
Thanks Much!
Parts Procurement
- dnewman
Re: Parts Procurement
Are these C46 and C49 which the original parts list and schematics show as 0.1 uF 50V?digitaladdictions wrote: CAP CER 1.0UF 50V X5S 0603
New part number at Digikey: ATMEGA88PA-AU-ND . When you lookup the old part number, Digikey kindly suggests this to you in the "possible substitute" box (in blue).IC AVR MCU 8K 20MHZ 5V 32TQFP
Newark / Farnell has a few of these in stock: part number 41K3322IC FREQ SYNTH DUAL 20TSSOP
Mouser part number 511-STN749. Digikey has discontinued carrying that specific part. Mouser is in the process of doing so. May be that the manufacturer has changed the part or part number?TRANSISTOR PNP 35V 3A HP SOT223
Cheers,
Dan
Yes they are C46 and C49. I was going off the parts list in the wiki. I have not really looked at the schematics yet in any detail.Are these C46 and C49 which the original parts list and schematics show as 0.1 uF 50V?
As for the freq synth and transistor THANKS I will order them tonight. I was not sure where to look other than digikey and mouser and for some reason mouser returned zero results when I used their search tool and entered the values on that transistor ... but now I can find it... I swear they had no SOT-233 and they are trying to make me look stupid now
