Wave Bubble 2010
The operation of transmitters designed to jam or block wireless communications is a violation of the Communications Act of 1934, as amended ("Act"). See 47 U.S.C. Sections 301, 302a, 333. The Act prohibits any person from willfully or maliciously interfering with the radio communications of any station licensed or authorized under the Act or operated by the U.S. government. 47 U.S.C. Section 333. The manufacture, importation, sale or offer for sale, including advertising, of devices designed to block or jam wireless transmissions is prohibited. 47 U.S.C. Section 302a(b). Parties in violation of these provisions may be subject to the penalties set out in 47 U.S.C. Sections 501-510. Fines for a first offense can range as high as $11,000 for each violation or imprisonment for up to one year, and the device used may also be seized and forfeited to the U.S. government.
Mictronics
Re: Wave Bubble 2010
Post by Mictronics »
For the following two plots the VCOs were tuned to there minimum frequency.
The digital potentiometer were set to maximum sawtooth amplitude, with NE555 set to high freqeuncy sawtooth mode.
Low band VCO, minimum frequency tuned, maximum sawtooth sweep
High band VCO, minimum frequency tuned, maximum sawtooth sweep
You can see the generated bandwidth of the VCO signal covers a few 100MHz on full sawtooth amplitude.
In my opinion this should be changed to cover maybe just 100MHz bandwidth at full amplidute.
Cause otherwise the bandwidth resolution which could be set by the digital potentiometer is quite low. A few KHz bandwidth per digit would be fine.
Mictronics
Here are two plots of the output power over the full VCO frequency range.
Low band VCO, full span output power sweep
High band VCO, full span output power sweep
Input level to PLL (with T-Attenuator between VCO and PLL):
Low band: -7dBm to -12dBm
High band: -8dBm to -20dBm
Next step will be testing the gain stage.
skygear
Post by skygear »
i'm getting very excited looks promising so far...
aqisnotliquid --->the black pcbs are a go for me by the way< if everything works out lets get a thread together for a bulk order
Mictronics
So folks, here are the results from measurements with amplifier installed.
The amplifier is a BANNED-84. Bias resistor is 1 Ohm and Vcc 5.8V. Both amplifier stages drawing a bit more than 100mA.
High Band, Max Power 1575MHz
High Band , Average Power 2450MHz
High Band, Max Power 2450MHz
Mictronics
High Band, Average Power 1575MHz
Low Band, Average 350MHz
Low Band, Max Power 350MHz
Mictronics
Low Band, Average Power 1280MHz
All in all the output power over the low band is around 10-14dBm average and 18-21dBm max power.
High band 7-14dBm averange and 14-20dBm max power.
Mictronics
Forgot one plot, 100MHz sweep from 2400-2500MHz, max power:
100MHz sweep, 2400-2500MHz, max power
aqisnotliquid
Post by aqisnotliquid »
The plots look great. I'm waiting for the final go ahead to put out a batch order.
losthorizonmba
Post by losthorizonmba »
Please count me in when you order batch of boards. Can make deposit
javajax
Post by javajax »
Let me know when you are doing the batch order I'll go in on it.
akula169
Post by akula169 »
Add me to the list as well
razorskiss1000
Post by razorskiss1000 »
I would be interested as well. So excited for this.
jarsnah12
Post by jarsnah12 »
I too would be interested. Let me know what the final cost would be to add me to the order.
echomike
Post by echomike »
also add me!
TheFallen
Post by TheFallen »
Just a thought an ATMega16u4 is a couple of quid cheaper than an FT232 and can do the sample function as a USB-serial converter, but then gives you a load of extra IO pins!!!!!!
See the Teensy for more inspiration.
Return to “Wave Bubble”
