WB 2010 Boards missing R43 Pads
The operation of transmitters designed to jam or block wireless communications is a violation of the Communications Act of 1934, as amended ("Act"). See 47 U.S.C. Sections 301, 302a, 333. The Act prohibits any person from willfully or maliciously interfering with the radio communications of any station licensed or authorized under the Act or operated by the U.S. government. 47 U.S.C. Section 333. The manufacture, importation, sale or offer for sale, including advertising, of devices designed to block or jam wireless transmissions is prohibited. 47 U.S.C. Section 302a(b). Parties in violation of these provisions may be subject to the penalties set out in 47 U.S.C. Sections 501-510. Fines for a first offense can range as high as $11,000 for each violation or imprisonment for up to one year, and the device used may also be seized and forfeited to the U.S. government.
Re: WB 2010 Boards missing R43 Pads
Postby spacedoggy » Fri Jul 29, 2011 8:17 am
correct me if I'm wrong but it looks to me like R45 is ok and our only problem is with R43...
I'll superimpose positions on your photo...
Again correct me if I'm wrong here. but would it be possible to 'ghetto mount' the R43 as a 1206 of equal value resistor between the gap.
SD.
spacedoggy
Postby Lcstyle » Fri Jul 29, 2011 9:13 am
spacedoggy wrote:correct me if I'm wrong but it looks to me like R45 is ok and our only problem is with R43...
SD.
You are definitely correct sir, don't know why I originally included r45 in this, perhaps my mind was tired and groggy. I have edited the post and thread title to WB 2010 Boards Missing R43 Pads, suggest you do the same to avoid confusion.
Ghetto rigging a 1206 SMD Resistor here is a solution (most likely one I will employ). Bridging from the existing pad over to the resistor with solder. Alternatively you can use a regular resistor of the same value (ugly).
I am not one for kludges, if you can't tell I am somewhat of a pedant.
EDIT ***
Use P22ECT-ND RES 22 OHM 1/4W 5% 1206 SMD for R43 on boards missing this pad.
Lcstyle
Previous
Return to Wave Bubble
Users browsing this forum: No registered users and 1 guest
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
