Hello...
I havent tried the RC1a as of yet, but does it require the same 'tweaks' or 'changes' that the RC1 did?
i.e. "Note that there are 3 minor errors in RC1: RX/TX swapped, missing 0.1uF capacitors for PLL output and the DC jack tip and ring-switch is swapped."
Or is it good to go right out of the Gate?
Thanks LadyAda!
RC1a Fully funtional?
- seanman3000
Awesome! Thanks!
So, no changes need to be made to the PCB before sending it off?
No tweaks, such as the ones mentioned in:
http://www.ladyada.net/forums/viewtopic.php?t=3010
What sort of Debugging would this require?
debugs
Even tho I took my sweet time with the surface mount soldering (ie several hours just for the power supply section) checking each component one by one and the traces and vias for continuity, with an engineer friend looking at schematics and datasheets, things still would not work.
That's the type of debugging we're talking about.
- seanman3000
Sounds laborious.... What sort of things can go wrong? Did you figure out why yours isnt working yet?
I guess I figured on some checking of my own work, but just was wondering if the Plan itself needed any tweaking, like the original one... Since some things were 'disabled' or 'crippled'
THanks so much!
THanks so much!
design is perfect
The WB design is electrically perfect to a great extent because it has to be for anything to function. The human condition is not. A tilt of the board can cause a tiny unseen hairball of solder paste left under an 0603 capacitor to bridge and short circuit a chip which in turn will apply a wrong voltage to the microcontroller, for example, shortly thereafter making it unusable. Tracing that can be the task of re-doing that section of the board. Desoldering can become brain surgery if you have no soldermasks and are using anything but a pro set of desoldering tools.
