inh wrote:Hi MightyG - very interesting. I note:
1- on the IF side you have the 1ohm (is that the value as per datasheet?) resistor before rather than after the c6/c5 input caps. I assume the WB post vco preamp signal also suffers some attenuation from the siphoning off to the PLL...
I get repeated transistor blows here when using values under 18 ohms ... (but not always!)
2- I tried replacing c5 (1.2pF) called c40 in the WB with 2.7pF on the RF side, between the vco and the transistor, and got a big power increase...
of course it may be a power increase too far with the 2230-119, but the SXB does claim to be capable of 500mA!
1. I am not using the 1 Ohnm resistor specified in the datasheet. The resistor following the VCO is 18 Ohm. This is for attenuation. I would get frequent tuning errors otherwise.
2. I might have to try the 2.7pF mod. I am still well under the 1/2W output on the 1900 side.
Would you mind posting a picture of your output/gain stage? I'm always interested in how others are placing the passives.
