Hey guys, I finished building my unit... I tested the led flash, and uart test.. both work.
Problem is when I load the default firmware with all tests commented out, i can't add a program... It asks for the values, i enter them but it never writes it to eeprom... After adding a new program and then printing it it shows 65535 for all values...
any suggestions?
I also tried the google code project code from another member here.. It seems to be a problem on my end, It just won't write the values to eeprom or something... Is there a fuse setting for that? am I programming it wrong.. I program the .hex file and .eep file, and I made it using ubuntu 8.10 and prorgammed using avrdude. (verify passes).
Firmware for wavebubble
Re: Firmware for wavebubble
I didn't figure out why neither program was working, but I did find a solution... Use the windows version for programming/compiling everything.
