Red and Blue make Purple right???
SpokePOV kit for bikes
scott02127
Post by scott02127 »
Okay, silly me, I purchased the SpokePOV kits before reading the overview section. Anyway I bought 2 kits one Red and one Blue for my daughters bike thinking I would put one on each tire. I understand (after reading the overview) that this would work and look good at around 15Mph. I would like it to look good at a lower speed too, so I was thinking of putting them both on one tire. Not only would this look better at lower speeds but it would be nice to keep the tire balanced. Anyway, I was wondering if anyone had done this with 2 different colors(red and blue in this case), and was there any negatives or positives in doing so? Red and blue should make purple, I hope...
Thanks,
Scott
The_Don125
Re: Red and Blue make Purple right???
Post by The_Don125 »
Red and blue would indeed make purple, and if you want to get fancy, you can now have a 4-bit color depth! Specifically, your images can now be red, blue, black, and purple.
kayrock66
Post by kayrock66 »
You may have trouble getting the color mix effect because the 2 LED sticks won't track closely enough, and those LEDs image as small bright point of light. But you might get some cool 2 color images.
JewelerChris
Post by JewelerChris »
Red and Blue make Magenta.
Our cone receptors are Red, Green, and Violet. What we consider "blue" is actually a mixture of violet and a little green, such as the 470nm blue LED, whereas a BANNED laser is actually violet (aka purple) at 405nm. Ultraviolet is considered 380nm-400nm, hence the term.
When blue and red are mixed, it creates the perceptual color Magenta (there is no wavelength for Magenta).
mtbf0
Post by mtbf0 »
of course, you won't get good color mixing 'til you get up to 15mph.
Return to “SpokePOV (discontinued)”
