Good afternoon, such variant of the scheme will work?????
Very much I look forward to hearing!!!!
Variant of the scheme for BMX???
- shm.rar
- (31.94 KiB) Downloaded 268 times
Re: Variant of the scheme for BMX???
Dear experts your opinion is necessary
We don't understand your question. Please restate.
Forgive me for my English, I very badly speak in this language, I wish to know the scheme awakes to work provided that I have cleaned a part of components?
What language do you normally speak? Does that .rar file have any connection to your query?
I well speak in Russian and on Ukrainski, shm.rar, it is the scheme, I have cleaned superfluous components for me, and wished to know быдет it to work?
If you post an image file (not .rar) I, and likely many others will look at it for you. Congratualations, your English is better than my Russian.
Here a picture
- 1.jpg (169.28 KiB) Viewed 3873 times
Okay this looks like you desire to make a BMX (short) Spoke POV that one has LEDs on one side of the board/bike. Looks like missed the J2 connector used to upload new images to the EEPROM or flash new firmware into the microcontroller if you ever want to do that as well. Apart from that it looks okay.
Forgive I has not understood, the device will work?
I am going to program with the help ponyprog what as much as possible to reduce the scheme
No the device will not work. You have provided no mechanism to upload new pictures to the EEPROM as would ordinarily be done with this design.
If you had the EEPROM pre-programmed either as it comes in the kit or in another SpokePOV device that did have the J2 connector it could be made to work, but would not be recommended. You're going to want to easily and quickly change images as you create your digital image masterpiece.
If you're doing your own board, you might consider a 3 battery design, perhaps using AAA cells to fit, so you can have the more exotic colors like pink, blue, green, white.
If to leave J2 that device will work, I have correctly understood you?
you do realize that you can use the existing design and just cut off the bottom 2" of the PCB, right?
flatron- yes, with J2, you will have a working design. And Ladyada is correct, the original SpokePOV design was done in a clever way with the intention of being able to cut off the last 8 LEDs and battery to fit on a BMX bike. I myself ran a pair of her boards assembled in this manner.
OK, I leave J2, my purpose to make only on the one hand LEDs
