HI !
At me a problem with SpokePOV. I live far, therefore the device I do itself. First, if the microcontroller not from the kit, what it is necessary to perform with it operations before programming? I have made the project minipov which successfully works. In it it has been told how to burn fuses.
The second, at program start SpokePOV v.1.4, arises an error:.....Failed to communicate with SpokePOV !... I have spent test. Has connected the device SpokePOV, but has started the program for work under the project minipov. Problems has not arisen. The microcontroller has been programmed successfully. The serial port is used. I think that communication computer with the device SpokePOV the successful. In what there can be a problem?
Thanks.
p.s. .... I am sorry for my bad English
problem of connection with a computer. Serial port
Re: problem of connection with a computer. Serial port
...a problem is successfully decided
