one of 3 mirrored
one of 3 mirrored
by chrisbe on Sat Nov 21, 2009 6:30 am
Hello!
I recently purchased and installed my spoke POV and discovered a strange Problem with it. One of the 3 boards seems to mirror the image. I tried to isolate the problem:
1. I checked the whole board very closely. Everything seems to be assembled right and no "cold" soldering joints.
2. It's not the software. I changed eeprom between boards. As far as i know this is the place where image patterns are stored. The problem remains with this particular board.
3. My suspicion went to the microcontroller. I took one from a good board an *täteretää* it works as it should. Image is displayed correctly and not mirrored.
Reverse: the "mirrored" microcontroller generates the false image no matter which board i clip it in.
Is it a bug in the microcontroller? (seems to me)
Do you have any ideas how i can fix this problem?
Chris
chrisbe
Re: one of 3 mirrored
by adafruit on Sat Nov 21, 2009 11:50 am
'mirroring' is stored in the microcontroller. so connect with the dongle and see if one has the box checked/unchecked
by tkuzeja on Fri Jul 27, 2012 10:38 am
I recently completed my SpokePOVs and find that I have this exact problem... one out of the three displays the pattern in reverse. I've assured that "Don't mirror" is selected in the software and when I read back from each device, "Don't mirror" is set in the combo box yet this one board displays its pattern mirrored.
Any suggestions as to how to debug this problem?
-Tom
tkuzeja
