I just made three blue spokepov units.
2 of the 3 work as expected. The third one doesn't respond well to the button push to turn it off.
When the batteries are inserted, the lights sequentially light. Pressing the button during this does nothing (this is the same as my other two units).
While 'idle', pressing the button for a short or long amount of time has no effect. On my other two units, holding the button for a second or so and then releasing causes the device to turn off.
When the lights are running (due to passing a magnet over the hall sensor), pressing the button 'freezes' them until the button is released. This is the same as my other units.
If I leave the device for 3 minutes, it shuts itself off fine.
I tried swapping the atmega chip with a working unit. The problem follows the chip. Is it possible that one of the timers or something internal to the chip is causing the problem? I have flashed the latest firmware to no avail.
Button problem
Re: Button problem
did it work before you reflashed the firmware?
- tcharron
Re: Button problem
I don't know. I did about 4 seconds of testing before I reflashed it (with the version on the support page at adafruit).
I'll spend some time comparing my three units and see if I can debug the problem. It does seem like a chip or firmware problem to me, and given that the chips usually don't fail I'm thinking it's more likely firmware.
Re: Button problem
4 seconds isnt a lot of testing
if youre sure its the chip you can email support@adafruit and ask for a new chip with link to this post
- tcharron
Re: Button problem
I isolated the problem and it isn't a hardware problem.
In SIGNAL(SIG_INT0), I added a set_led(timer%32,FRONT) in the first while statement. It seems that this loop is running very slowly (which can only be caused by the delay_ms routine). By changing BUTTON_DEBOUNCE to 2 and the 500 in this routine to 15, I got the desired results. The 'progressing' lights while the button is held down help too.
I think that the pre-installed firmware is slightly different than the one I generated from the published source code. I didn't try to decode the delay_ms routine. I'm using WINAVR 20090313 - not sure if that makes a difference.
- tcharron
Re: Button problem
Further update...
Replacing delay_ms with the following fixed the issue entirely (without requiring changes to the other timing parameters):
I imagine that this also has the benefit of a smaller binary image too.
void delay_ms(unsigned char ms) {
while ( ms-- ) _delay_ms(1);
