Mirror and Don't mirror - problem
by Kama on Sun Jul 18, 2010 3:48 pm
Why at mirror inclusion to the programmed image the shone strip is added? Look the attached screenshot. At normal inclusion (not mirror) everything is all right. How to get rid of it?
Regards
Kama
Re: Mirror and Don't mirror - problem
by Kama on Tue Jul 20, 2010 12:31 am
Nobody knows? What can be? In pictures of users the same problem - look. On the mirror party there is a parasitic luminescence of LEDs.
Kama
by adafruit on Sat Jul 24, 2010 12:02 pm
hmm, thats a bug we havent heard of before. does it move if you change the magnet position?
by Kama on Sun Jul 25, 2010 11:55 pm
Position of a magnet does not correct a question. If the image is located on all area - then this luminescence is not visible. If the image is located not on all area - then there is a parasitic luminescence :(
Kama
by matajumotors on Tue Jul 27, 2010 11:07 am
There already was solution for this bug on forum, cant find it now. That "line" is last line of previous image or first of next image cant tell for shure =]
But You must change this (in main.c):
  if (sensor_timer < ((F_CPU/NUM_PIXELS)/256 * STANDBY_TIMEOUT)) {
    // less than ~5 seconds since last sensor
    PORTA |= 0x1;
    eepromaddr %= NUM_PIXELS * 4;
    spieeprom_read_into_leds(eepromaddr + anim_eeprom_offset, FRONT);
    if (mirror) {
      spieeprom_read_into_leds(anim_eeprom_offset + (1024UL-eepromaddr), BACK);
    } else {
      LATCH_SELECT_PORT |= _BV(BACK);
      NOP; NOP; NOP; NOP;
      LATCH_SELECT_PORT &= ~_BV(BACK);
to this:
    PORTA |= 0x1;
    if (mirror) {
      spieeprom_read_into_leds(anim_eeprom_offset + (1024UL-eepromaddr)-4, BACK);
    } else {
      NOP; NOP; NOP; NOP;
Some of my projects here -> http://kaspars.id.lv
matajumotors
by Kama on Tue Jul 27, 2010 7:18 pm
Thanks. I will try.
Kama
by Kama on Wed Jul 28, 2010 6:07 pm
matajumotors wrote:There already was solution for this bug on forum, cant find it now. That "line" is last line of previous image or first of next image cant tell for shure =]
    PORTA |= 0x1;
    if (mirror) {
    } else {
      NOP; NOP; NOP; NOP;
to this:
    PORTA |= 0x1;
    if (mirror) {
    } else {
      NOP; NOP; NOP; NOP;
Only I have not understood - how to make these changes? Where to make changes? The special program is necessary? Help, please :|
Regards
Kama
by matajumotors on Thu Jul 29, 2010 12:50 am
Personaly i am using AVR Studio, but the easiest way i think, is to download firmware, there will be source files, make file and hex file. edit the main.c in notepad (add "-4"), save and compile it with the make file, search site for tutorial using make files. Then upload new hex to spokepov.
matajumotors
by Kama on Thu Aug 05, 2010 5:48 am
Thanks. If I make changes - all will earn normally? And not the mirror party also will be normal to work?
P.S. How with you to communicate? I have a question concerning your project on a site http://kaspars.id.lv (a lantern for a bicycle). My server gives out an error at letter sending :-( My address kama95@rambler.ru
P.P.S. Do you speak in Russian? :wink:
Kama
by matajumotors on Fri Aug 06, 2010 2:00 pm
If you will change that, everything will work as it should. =] Da, ja govorju po russki =] mail is working.
matajumotors
by tony18183 on Sat Feb 25, 2012 11:36 pm
Hi
May I know how to upload the new firmware into Spokepov with USBtiny?
tony18183
