Wrong resistor networks?
by Punkshnitz on Sat Aug 27, 2011 2:37 am
Hi, just building my first lot of spokePOV's and just a quick querie. Noticed on the parts list it states that blue LED's require a 56 ohm but the kit was shipped with 68 ohm which the parts list says is for the green.
Don't want to install them till I know for sure cheers!
Punkshnitz
Re: Wrong resistor networks?
by adafruit on Sun Aug 28, 2011 5:24 pm
its all good, we tweak em for the LEDs as long as its kinda close its ok!
by jrfoell on Fri Jan 27, 2012 12:52 am
Not to necro this post, but it is relevant...
I cracked one resistor network, and bought a replacement 27 Ohm (I have yellow LEDs). Then I noticed the kit included 39 Ohm resistor networks. Is one resistor being different going to effect LED brightness, heat, longevity, etc. (should I get 39 Ohm to match)?
jrfoell
by adafruit_support_bill on Fri Jan 27, 2012 7:16 am
27 ohms will be slightly brighter than 39. Heat and longevity effects will be insignificant. For best appearance you probably want a matching network.
