Problem. LED are not shone.
SpokePOV kit for bikes
Pro29
Post by Pro29 »
I've soldered up my board. There were problems of the microcontroller.
In Makefile has changed:
#AVRDUDE_PROGRAMMER = dt006
AVRDUDE_PROGRAMMER = dasa
#AVRDUDE_PROGRAMMER = avrisp
to
#AVRDUDE_PROGRAMMER = dasa
and
AVRDUDE_PORT = com1        # programmer connected to serial device
#AVRDUDE_PORT = /dev/cu.PL2303-2B1        # programmer connected to serial device
#AVRDUDE_PORT = lpt1    # programmer connected to parallel port
to
#AVRDUDE_PORT = com1        # programmer connected to serial device
I succeeded to program it, and it not see any flash LED. wxSpokePov is connected to device ok. In what there can be a reason not shone LED?
P.S. Excuse for my English :)
Post by adafruit »
did you buy a kit?
Pro29
Post by Pro29 »
No, i'm buy "SpokePOV Kit PCB" and soldered up my board.
Post by adafruit »
do the leds light up one after the other when batteries are inserted?
Pro29
Post by Pro29 »
Leds did not light up never. I'm tested all leds - leds is ok!
Post by adafruit »
something is wrong with your latches, i'd guess
Pro29
Post by Pro29 »
I have similar found the reason! I have incorrectly soldered in LEDs. :oops:
Pro29
Post by Pro29 »
I'm soldered up my board. By default, board is ready ok. New problem found: "Spokepov v1.2" program not write to EEPROM new image...
Return to “SpokePOV (discontinued)”
