No Lights, Hot Battery !!
by acestu on Mon Oct 29, 2012 2:42 pm
Hi Could somebody help please, I have just built 1 of my spoke povs however when I put the batteries in nothing lights up and one of the batteries gets red hot.
thanks in advance
Acestu
acestu
Re: No Lights, Hot Battery !!
by acestu on Mon Oct 29, 2012 3:24 pm
I have checked the board and the only thing that I am uneasy about are the resister arrays, I positioned them with the white dot where the writing is to the x on the printed circuit board , hope that is the right way....
thanks
Acestu
acestu
by acestu on Mon Oct 29, 2012 5:46 pm
Here are some pics if this helps, I removed the hall effect sensor in case it was wrong way round but no different
http://imgur.com/a/cu9aT
thanks
Acestu
acestu
by adafruit_support_bill on Mon Oct 29, 2012 8:07 pm
Which one of the batteries is getting hot? Some clearer photos of the area around that battery holder would help. More light should give you better photos. Try near a window or even outside.
by acestu on Tue Oct 30, 2012 1:40 pm
Hi, I have added some more pics of around the battery clips, also the batterry is the one nearest to the square end of the pcb and it gets hot even if I put just that 1 battery in its clip.
Hope this helps
thank you
Acestu
acestu
by adafruit_support_bill on Tue Oct 30, 2012 2:05 pm
The third battery position is only for blue, green, white or purple LEDs. To use that, you need to cut a trace as described in the "prep" section of the tutorial.
For all other colors, you should use only the first two battery positions as shown:
by acestu on Tue Oct 30, 2012 2:45 pm
OMG , I cannot believe I made such a stupid mistake, what through me was the cut trace writing on the battery position that I should of used, Oh well all working thank you support...
cheers
Acestu
acestu
