pleace need help form argentina
SpokePOV kit for bikes
Postby migueloco » Sat Jul 07, 2007 5:31 pm
C:\1>make full
make burn-fuse
make[1]: Entering directory `C:/1'
avrdude -q -p attiny2313 -P com1 -c dasa -u -U lfuse:w:0xe4:m -U hfuse:w
:0x9d:m
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x1e910a
avrdude: reading input file "0xe4"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xe4:
avrdude: load data lfuse data from input file 0xe4:
avrdude: input file 0xe4 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: verifying ...
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0x9d"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0x9d:
avrdude: load data hfuse data from input file 0x9d:
avrdude: input file 0x9d contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude done. Thank you.
make[1]: Leaving directory `C:/1'
make program
Creating load file for EEPROM: spokepov.eep
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O ihex spokepov.elf spokepov.eep
c:\WinAVR\bin\avr-objcopy.exe: there are no sections to be copied!
c:\WinAVR\bin\avr-objcopy.exe: --change-section-lma .eeprom=0x00000000 never use
d
make[1]: [spokepov.eep] Error 1 (ignored)
avrdude -q -p attiny2313 -P com1 -c dasa -U flash:w:spokepov.hex
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "spokepov.hex"
avrdude: input file spokepov.hex auto detected as Intel Hex
avrdude: writing flash (1936 bytes):
avrdude: 1936 bytes of flash written
avrdude: verifying flash memory against spokepov.hex:
avrdude: load data flash data from input file spokepov.hex:
avrdude: input file spokepov.hex contains 1936 bytes
avrdude: reading on-chip flash data:
avrdude: 1936 bytes of flash verified
avrdude: safemode: Fuses OK
help !!!!! 1 error and no work
hardware is OK, and no work !!!!
de attiny is blank,
my frist program in attiny
pleace help
migueloco
Return to SpokePOV
Users browsing this forum: VeleBookSot and 4 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
