Re-posting at top level to get more visibility:
I've made a patch porting wxSpokePOV to Linux. Any of you who would like to try this out should run:
cvs -z3 -d:pserver:[email protected]:/cvsroot/spokepov co wxsoft
cd wxsoft
wget http://newview.org/jsha/spokepov-linux-patch.txt
patch < spokepov-linux-patch.txt
less Makefile.linux
make -f Makefile.linux
Make sure to read the Makefile! It has comments in it on what libraries you need installed. In particular you are likely to need to compile your own version of wxGTK, since the version that comes with your distribution may be compiled with --enable-unicode, and wxSpokePOV needs a non-Unicode wxGTK.
Ladyada, if this works for you, any chance of integrating this into the mainline?
wxSpokePOV ported to Linux
Any word on this? I never got a response. BTW, the patch file is now available at http://jacob.hoffman-andrews.com/spokep ... -patch.txt.
- bensch128
Problems using spokePOV on linux in usb mode
I got the first spoke (and programmer) soldered together and hooked up to my linux machine. I'm trying to program it over usb but I'd hitting a communication error.
In communication.cpp line267
n = usb_control_msg( usb_handle,
USB_ENDPOINT_IN | USB_TYPE_VENDOR | USB_RECIP_DEVICE,
req, val, index, (char*) buf, buflen, timeout );
always returns -1 (yeah for debuggers!!)
Can anyone give me a hint about how to make sure communication is working correctly?
Thanks for the awesome project!
Ben
PS. a multicolor spokePov kit ala kayrock66's project would kick ass.
I'd buy that in a second.
Ben
- bensch128
Got it working
I forgot to use sudo when running the spokepov program... duh!
It works great. Now how can I make it multi-colored???
Thanks for the amazing kit,
It was so asy to throw together
Re: wxSpokePOV ported to Linux
jsha, what great work to port it to Linux!
I just soldered the POV together and now i want to play with it.
Am i correct when i say that your port only supports the serial port? i read that on your site.
I guess not because bensch128 says he uses USB... what do you use bensch?
Thanks the hard work and the sharing.
EJ
Edit:
This is what i get when i want to compile:
spokepov.cpp: In member function ‘virtual bool SpokePOV_App::OnInit()’:
spokepov.cpp:52: error: cannot convert ‘const char*’ to ‘const wxChar*’ for argument ‘1’ to ‘void wxLogDebug(const wxChar*, ...)’
spokepov.cpp:56: error: conversion from ‘const char [11]’ to ‘const wxString’ is ambiguous
/usr/include/wx-2.6/wx/string.h:643: note: candidates are: wxString::wxString(wxChar, size_t) <near match>
/usr/include/wx-2.6/wx/string.h:633: note: wxString::wxString(int) <near match>
spokepov.cpp: In member function ‘bool SpokePOVFrame::LoadConfiguration()’:
and so on.
I set LD_LIBRARY_PATH to where i compiled wxWidgets.
any ideas?
EJ
Edit:
and so on.
any ideas?
- bensch128
Hi EJ,
You have to compile wxGTK WITHOUT unicode (--disable-unicode).
Then you need to set your first include path to point to where it's installed.
That should get rid of the compile errors.
Cheers
Ben
Cheers
Ben
- bensch128
Oh and I used the USB connection without a problem.
I just had to run wxspokepov with sudo to use the usb device.
Use lsusb to figure out which device the cable is plugged into.
Cheers
Ben
Cheers
Ben
hi Ben,
thanks for your info!
I see now that my standard install of wxGTK is used, which is of course not correct because of the unicode.
However, when i want to compile and install wxGTK with the "--disable-gtk2 --disable-unicode --enable-monolithic" options (as stated in the Makefile), i cannot do a make install.
I get this error:
/usr/bin/install -c -d /usr/local/share/aclocal
(cd . ; /usr/bin/install -c -m 644 wxwin.m4 /usr/local/share/aclocal)
/usr/bin/install: cannot stat `wxwin.m4': No such file or directory
make: *** [install] Error 1
Annoying, since i can't seem to find any info on that error message. The wxwin.m4 file is sitting happily in the directory from which i did the compile.
The make process ends OK, only "make install" complains.
wx-config can't find the custom install and $LD_LIBRARY_PATH does not seem to work when i point it to the target directory.
I can see the libwx_gtk-2.8.so, libwx_gtk-2.8.so.0 and libwx_gtk-2.8.so.0.5.0 sitting right there.
Very strange.
Any ideas anyone?
I get this error:
Very strange.
Any ideas anyone?
- bensch128
I bet you need to do "sudo make install". /usr/local not writable by the normal user.EJ99 wrote:
I get this error:
good call!
you are right, but the thing is i wanted to install wxGTK in a local dir. otherwise it would interfere with the standard wxGTK that packet-manager placed on my system.
in the case of installing into a local dir i get the wxwin.m4 problem. "make install" should not be necessary, if i could point to the local dir but that does not work.
i used an alternative install that i don't use much, i removed the standard system wxGTK, compiled my own version and now it almost works, only the "connect"-button does not want to show.
maybe i will create a LiveCD for SpokePOV when i get it all to work.
cheers,
EJ
cheers,
EJ
i'm very sorry to post this, but after hours of work the compile still is not correct.
the port needs some work in the Makefile.
when wxGTK is already installed there is no way to add a custom compile with the options set as mentioned in the Makefile.
now i have soldered everything together and it still does not work.
fisrt off this:
I want to thank jsha for his excellent port, and Ben for his support, thanks!
And ladyada for this great project!
OK i finally got it to work on Debian.
This post is intended as a last resort, in case the normal install does not work.
I had to create this because wxGTK was already on my machine and i had to keep it clean, so i could not install another version of wxGTK with otjer compiler options next to it. They would clash.
For all you Ubuntu users, Debain almost never uses " sudo " so that's why i don't use that.
Here goes:
cd wxsoft
wget http://jacob.hoffman-andrews.com/spokep ... -patch.txt
i needed to edit the Makefile.linux.
Copy it first:
cp Makefile.linux Makefile.linux-ori
GTK:
i installed wxGTK in /home/user/wxGTK/2.8.9. wxGTK was already installed on my system and i did not want another version to conflict.
i compiled it with
./configure --disable-gtk2 --disable-unicode --enable-monolithic --prefix=/home/user/wxGTK/2.8.9
make
make install
edit Makefile.linux:
i replaced 3 lines.
the original lines:
LDFLAGS_GUI = `wx-config --libs`
CPPFLAGS = `wx-config --cxxflags`
EXTRALIBS = `wx-config --libs` -lusb
the modified lines:
LDFLAGS_GUI = `/home/user/installs/wxGTK/2.8.9/bin/wx-config --libs`
CPPFLAGS = `/home/user/installs/wxGTK/2.8.9/bin/wx-config --cxxflags`
EXTRALIBS = /home/user/installs/wxGTK/2.8.9/lib
to make the spokePOV software do
if you have to compile again, first do
make -f Makefile.linux distclean
it cleans up and allows you to recompile with everything reset, so compile will listen to changes you make.
to run your program do ./spokepov
i have to run spokePOV as root on my machine.
if it complains about not finding a wxGTK library, we have to make a small adjustment.
we need to do a dirty hack, but i cannot find another way to do it.
export LD_LIBRARY_PATH=/home/user/wxGTK/2.8.9/lib
now you can run spokepov.
edit: one more thing: i had to make the spokePOV-window bigger to see the "connect" button. maximizing the window helps too
EJ
Here goes:
cd wxsoft
Copy it first:
GTK:
i compiled it with
make
make install
i replaced 3 lines.
the original lines:
the modified lines:
EJ
- jason0x21
I seem to have gotten the instructions immediately above to work, however I can't seem to load a BMP into the program. Do I actually need to have a SpokePOV connected to try out the program and see if I've at least got bitmap file import working (that seems a little backwards)? I'd like to know that the program is sort of correct before plunking down my cash Thanks.
Also, if you have to build wxWidgets from scratch to get around the unicode problem, add "--disable-shared" to the configure command, so that when you get around to building the spokePOV program it will statically link the wxWidgets library into the executable, and you won't have to fiddle with the whole LD_LIBRARY_PATH thing. Like this...
./configure --disable-gtk2 --disable-unicode --disable-shared --enable-monolithic --prefix=/local/wxGTK/install/path
yup it requires a spokepov connected. that said, hundreds of people have managed to get it working so it -does- work
- jason0x21
I can dig it. Being a Linux-only guy, I wanted to make sure I'd gotten as much working correctly as I could before making the next step (especially since the process is "apply this patch to the official software"). Thanks! SpokePOV now ordered!
