This was similar to one of my questions. To paraphrase, for my situation,
Can this be used on automotive rims? I have a vehicle with cast rims - there are small openings in the cast. Ultimately, I would like to be able to use a magnetic pickup so the board need not be mounted inside the rim in order to connect the LEDs. If not possible, then I'll just put the board inside the rim - centrifugal force will help keep it there when mounted with double sided tape (like balancing weights.)
Thanks in advance!
