8 leds not working on battery side
SpokePOV kit for bikes
staticguy
Post by staticguy »
I just put my first one together last night and 8 leds on battery side, above RN3 and IC5 do not light up.
Everything else works fine. The dongle worked and i was able to update the images, and other than the blank spot it is too cool.
I checked the traces with a meter and the resistor pack looks fine, and there is nothing shorting out anywhere.
Did I fry IC5 installing it? I have 2 more kits so i can swap it out, but don't want to if that's not the bad part.
rabbidator
Post by rabbidator »
maybe you put RN3 or IC5 backwards?
staticguy
Post by staticguy »
both are in the correct direction.
Post by adafruit »
do all the OTHER leds work?
staticguy
Post by staticguy »
ladyada wrote:do all the OTHER leds work?
They all work fine. Both in the chase on powerup and in displaying images.
staticguy
Post by staticguy »
I just built up an other one and it's working fine.
Maybe I shorted out R3 on the spokes when i installed it. It is a flat areo spoke that could get right up next to the contacts.
I warped the spoke in electrical tape this time before installing the new one.
Post by adafruit »
it def sounds like the resistor pack is damaged and -not- the latch. they're much easier to replace, which is good!
Return to “SpokePOV (discontinued)”
