Laser Cutting ITO PET Samples
by matthewelse on Thu Apr 04, 2013 12:46 pm
I have recently purchased some of the Adafruit ITO coated PET pieces online, and I was wondering whether anyone has had any success laser cutting these, or engraving these to remove the ito to make specific traces. Should I try laser cutting, or am I risking breaking it, or should I stick to cutting them by hand.
matthewelse
Re: Laser Cutting ITO PET Samples
by adafruit on Tue Apr 16, 2013 11:38 pm
PET is very soft, you can likely score the ITO off at very low power. but do a bunch of tests at the edges first..then let us kniw, we are very curious :)
by westfw on Wed Apr 17, 2013 3:09 am
Many plastic stores will have NON-ito-coated PET sheets in various thicknesses; much cheaper to experiment with!
PET == Mylar == Polyester film; the same stuff as most transparencies, for instance. (except SOME are "acetate")
http://www.dunmore.com/technical/pet-film.html
(OTOH, differences in thickness and production techniques can drastically change the way a plastic film behaves. I think "Shrinky-dink film" is also PET, but clearly not all mylar behaves that way. (and ever heat up an empty soda bottle (also PET) in an oven?))
westfw
by kursat on Thu Apr 16, 2015 9:37 pm
I just was able to engrave a touch pad from ITO on PET.
I've used the following cutter I have and diamond engraving tips.
It was only able to engrave only with diamond tips.
http://knkusa.com/product/knk-zing-air-2/
I've used 10 speed and 60 force initially, but probably I can go much lower.
Trace width initially was 0.5mm but I think I can finer as well..
The touchpad will be used with mpr121 capacitive sensor.
kursat
