I'm looking for a laser that would have a minimum range of 600 m and with a divergence less than 300 mm in diameter at 600 m, is TTL laser diode 1056 suitable for that? or is there any recommendation?
By range I mean it can still be visible clearly regardless of day or night.
What is the range of a TTL Laser Diode 1056?
Re: What is the range of a TTL Laser Diode 1056?
You might be able to achieve that divergence requirement, but I doubt that you would be able to see these in daylight at 600m. You should look into some higher powered laser modules.
