Moleskine Engraving Settings
by AK Chris on Mon Jun 02, 2008 3:09 pm
Didn't see it on the Wiki, so I thought I'd ask here. Anyone know the settings for engraving a moleskine? I will have a Universal M360 60watt by the end of the month and am planning some Thank You gifts for artists who recently participated in an exhibit I curated.
Chris
AK Chris
what exactly is the substrate?
by LaserGregg on Tue Jun 03, 2008 8:01 pm
I looked up what a moleskine is.
Is it a paper product? let me know, I can advise what to look for when running tests.... you get one shot.
LaserGregg
by AK Chris on Tue Jun 03, 2008 9:56 pm
They are an oil skin covered notebook modeled after the ones that the likes of Picasso, Hemmingway, Van Gogh, etc. Used. They are popular with artists, etc. I've carried one for years. They fit nicely in your back pocket so you can record your "brilliant thoughts" as they occur (mine is mostly empty...ha ha).
It is quite popular to engrave them right now....
Thanks for your help!
AK Chris
two choices I see from here
by LaserGregg on Wed Jun 04, 2008 9:31 am
2 choices are this....... etch it enough to make your mark... or
nuke it so it looks stamped or branded with a "deep relief"...... you have to decide this.... also dpi and clarity affect your performance.
depending upon your medium.... which will harm the cover the least.
with 60 watts you could evaporate the whole thing.
http://www.opticaletching.com/OEINKLESS.jpg
I'm the Etchician...not the artist.
LaserGregg
by AK Chris on Wed Jun 04, 2008 10:28 am
I just want to laser/brand the surface. I don't want to burn through the cloth covering. I may have to drag out an old one and experiment. I just wasn't sure where to even start as far as settings and go from there.
Thanks for your input.
AK Chris
If it was all about settings.........
by LaserGregg on Wed Jun 04, 2008 10:43 am
you would know a dozen etchers......
this is a feel thing like guitar or cooking.
screw something else up first.
work into it..... but test wood first.....
paper would be finer.... and an oil paper would be finer due to the finish in my opinion.... I forgot to ask photos?
and whats the size of your table?
LaserGregg
by AK Chris on Wed Jun 04, 2008 11:47 am
If I understand correctly every laser is different so recommended settings are just starting points anyway.
-Not sure what you mean by photos.....what I intend on engraving or of the moleskine?
- Universal M360 60 watt with a 12" x 24" table.
AK Chris
Photos
by LaserGregg on Wed Jun 04, 2008 12:50 pm
I'm kind of cryptic when it comes to descriptions.
There's no guild of etchers.
wood test pic... same photo three ways..... different settings
photos, text and both require a skilled technique.
http://www.opticaletching.com/testw.jpg
LaserGregg
by AK Chris on Wed Jul 09, 2008 4:53 pm
Just a follow up on the settings I settled on for engraving moleskines with my 60watt Universal:
15% power
100% speed
250 PPI
Hope that is of use to some of you out there...
Chris
AK Chris
thats etching......
by LaserGregg on Thu Jul 10, 2008 1:52 pm
Did you notice how when the settings changed, what you wanted out of the etch did also? most users do not have 60 watts...... so the settings will change the look you want of the etch. link up a pic.....
LaserGregg
Re: thats etching......
by AK Chris on Mon Jul 14, 2008 3:33 pm
[quote="LaserGregg"]Did you notice how when the settings changed, what you wanted out of the etch did also? most users do not have 60 watts...... so the settings will change the look you want of the etch. link up a pic.....[/quote]
Since I'm a rank amateur, I went from putting a deep, crispy "brand on my wife's notebook to the desired result in several shots. I used the ULS recommended setting for leather and then backed off until I got the desired effect with no charring. I'm at my "real job" right now so I'll take some pics when I get home.
I did 14 for a friend's wedding and they went over well. I also did their leather guest book and found I had to crank it up to 22% to get the desired effect.
AK Chris
The Best Etcher in Alaska.
by LaserGregg on Mon Jul 14, 2008 4:07 pm
now you are pro.
Its a 10 hour stare at a 10 foot putt.
60 watts can do a lot.
doesn't etched leather smell great?..... hmmmmmm
LaserGregg
by AK Chris on Thu Jul 17, 2008 6:09 pm
A pro already? Gee, I guess I should start charging more!
All seriousness aside, I just did my first leather the other day. Either I have a great ventilation system or I didn't get the full effect. I ddn't cut just engraved an image onto a wedding guest book. I didn't see any charring, it just lightened the surface and gave it an embossed look. Nice result. I'm going to try cutting some veggie tan leather I have next to prototype out some knife sheaths for a friend who is a knifemaker. I expect to get the full odiferous experience then!
I've only been at this for less than a month but its clicking. I bought my unit used and had it shipped up here to my little island in Alaska. I read everything I could, asked the seller a few questions, checked out forums like this and was burning away before the rep ever got up here. He showed me some maintenance, some Corel tricks, helped me diagnose an air assist issue and was surprised how much I was already doing.
There is no substitute for just rolling up your sleeves and doing it.
Chris
AK Chris
Nice!
by LaserGregg on Thu Jul 17, 2008 6:52 pm
so I give good advice? cut 1/8" leather tile and you'll smell it.
its a feel. you have to know your heat, your file and your time.
I was cutting 1/4" acrylics 5 hours straight last night til 3 am for a friend who drove two hours to get to me each way. prices vary with loyalty here. its a 10 hour stare at a 10 foot putt.
LaserGregg
by adafruit on Thu Jul 17, 2008 7:40 pm
BTW, moleskines are made with PVC (vinyl) and create chlorine gas when heated (with a laser, for example)
it is toxic to humans/animals and destructive to the laser, even with a filter system
http://www.ladyada.net/rant/2008/07/mol ... ntain-pvc/
a few moleskines wouldnt do much damage, but if it was going on got 5-6 hours a day, 5 days a week that could make an effect.
personally i dont think its worth the risk, but it may be for others, it depends on how much liability you are interested in carrying.
