I purchased the jpeg camera. I have been able to take pictures, so I know it works, but when I try the motion control sketch I get the following:
VC0706 Camera test
Camera Found:
VC0703 1.00
Ctrl infr exist
User-defined sensor
525
Image size: Motion detection is OFF
My configuration is pretty simple, so not sure what the issue is. I am running with uno/sd shield from sparkfun/proto shield with camera attached. The SS pin of the sd shield is re-wired to pin 10. I have the camera pins wired as follows rx=3,tx=2, power=5V, and ground=to duino ground. I am using the Arduino 1.0 IDE(I also tried with 1.01, but same result). I downloaded the most recent version of the code of github. Any ides on what the issue might be?
Thanks,
-ren
