Brain Machine
Breakout boards, sensors, Drawdio, Game of Life, other Adafruit kits, etc.
Brain Machine
Postby cshiley » Sun Dec 05, 2010 2:07 pm
Does the Brain Machine use binaural beats?
cshiley
Re: Brain Machine
Postby adafruit » Sun Dec 05, 2010 3:29 pm
good question, this is something best answered by mitch we'll get him to pop in here.
Re: Brain Machine
Postby mtbf0 » Sun Dec 05, 2010 5:18 pm
yes. see the firmware.
mtbf0
Re: Brain Machine
Postby maltman23 » Sun Dec 05, 2010 5:39 pm
Binaural beat is a perceptual phenomenon in which a person perceives a beat frequency.
A beat frequency is a physical phenomenon where sound pressure waves from two different frequency soundwaves add and subtract in front of your ear drum -- you actually hear the two original frequencies, and you also hear the difference between the two frequencies. (People who play guitar often make use of beat frequencies to tune two strings by plucking both strings after positioning their fingers on the fret-board appropriately, and tuning one string until the beat frequency goes down to zero.)
70% of people perceive binaural beats. Of the people that do not perceive them, more are female. No one knows why binaural beats are perceived, but it has something to do with the communication between brain hemispheres.
The Brain Machine makes use of binaural beats. The idea is that your brain is involved in creating the perceptual phenomenon of hearing the (non-exitent) "beat frequency" (and the AVR microcontroller is programmed to have the binaural beats be brainwave frequencies) -- and because your brain is involved in creating the perceived beat frequency, it is effective in synchronizing your brain to that frequency.
The binaural beats that the Brain Machine puts out into the headphones are always the same as, and in synch with, the blink rate of the LEDs in front of your eyes.
The idea is that the blinking lights together with the binaural beats make it even easier for your brain to synchronize to the pre-programmed meditation brainwave sequence (and so you meditate).
The beautiful hallucinated colors and patterns that everyone perceives are only from the blinking lights.
Mitch.
maltman23
Re: Brain Machine
Postby cshiley » Mon Dec 06, 2010 11:03 am
Thanks very much for the quick answer!
cshiley
Re: Brain Machine
Postby gr33nman » Thu Feb 10, 2011 5:58 pm
Is there anywhere on the web where there are other example light and sound 'shows' for Mitch Altman's brain machine that people have created and found interesting or useful, for instance, for falling asleep, conscious dreaming, perhaps using alternate frequencies, etc. For instance, some may prefer 7Hz instead of 6Hz for Theta. Is there anything like that out there? It would just be a case of switching out the contents of brainwaveTab[] for another table.
gr33nman
Re: Brain Machine
Postby maltman23 » Fri Feb 11, 2011 12:58 am
A bunch of people have posted to the blog pages for the project on the MAKE Magazine site (where my original project article was published):
http://makezine.com/10/brainwave
But you can easily change the brainwave sequence on your own and see what results you get. Go ahead and play. And please post your results so that others can benefit from your experience.
Best,
Mitch.
maltman23
Re: Brain Machine
Postby gr33nman » Tue Feb 15, 2011 2:18 pm
maltman23 wrote:A bunch of people have posted to the blog pages for the project on the MAKE Magazine site (where my original project article was published):
Best,
Mitch.
Hi Mitch,
Thanks for your reply. I've just commented about my Arduino Brain Machine blog post on Makershed. There's a git repository too.
I'm interested in compiling a list of other people's brainwave duration tables to help spread around what others have come up with.
Arduino is a little easier for me to hack - plus I got one for Christmas, hence my interest in working on that platform.
I'm working on alternate blinks, adding other frequencies and smooth ramps transitions.
I hope you like what I've done.
Cheers,
Chris
gr33nman
Re: Brain Machine
Postby maltman23 » Sat Feb 19, 2011 2:54 am
Hey Chris,
Cool that you're hacking it on the Arduino. Thanks for sharing the project. Please post to here and the Makezine blog page for the project if you get any results you like (or don't like).
Cheers,
Mitch.
maltman23
Re: Brain Machine
Postby gr33nman » Sun Feb 20, 2011 2:51 pm
maltman23 wrote:Hey Chris,
Cheers,
Mitch.
Hi Mitch,
I elected to use the tone library to generate tones for the Arduino instead of creating tones manually. For that reason, all of the code regarding this is stripped from my adapted code. Just to be sure the tones were correct, I generated equivalent square-wave tones using Audacity. They are nearly identical to my ear - close enough to rely on the binaural beats generated by the tone library.
I used a central tone:
float centralTone = 440.0;
and an array of beats:
float binauralBeat[] = { 14.4, 11.1, 6.0, 2.2 };
so the code plays beta thus:
rightEar.play(centralTone - (binauralBeat[0]/2));
leftEar.play(centralTone + (binauralBeat[0]/2));
This allows users to choose whatever general pitch they might like to start with and never have to fiddle with exact tones after that. The code does the rest for us. Also, allowing the tone to go up and down equally in both ears may seem more 'natural' to some listeners than leaving one tone unmoving in one ear.
So if someone wanted to add gamma to their set,
it's a case of changing float binauralBeat[] to
float binauralBeat[] = { 14.4, 11.1, 6.0, 2.2, 40.4 };
and adding the case:
    case 'g':
      // Gamma
      rightEar.play(centralTone - (binauralBeat[4]/2));
      leftEar.play(centralTone + (binauralBeat[4]/2));
      // Generates a binaural beat of 40.4Hz
      // delay for the time specified in the table while blinking the LEDs at the correct rate
      blink_LEDs( pgm_read_dword(&brainwaveTab[index].bwDuration), 124, 124 );
      return;   // Gamma
just before the default case of switch(brainChr).
To my eye and ear, binaural beat and blinks are matched, at least when they are slow enough that my brain can make the distinction, like theta and delta.
gr33nman
Re: Brain Machine
Postby maltman23 » Sun Feb 20, 2011 6:31 pm
Thanks for posting this, Chris.
I made a reply on the blog page for the Brain Machine project on the makezine site:
http://makezine.com/10/brainwave/
So, anyone interested, please look over there, too (do a search for "gr33nman" once the page loads).
Cheers,
Mitch.
maltman23
Re: Brain Machine
Postby GregW » Thu Apr 21, 2011 12:57 am
I just got an Uno as well so I was pretty excited to come across this topic!
Mitch, I have had my eye on this for a while...really excited to get one going...nice work!
Chris, like you I wanted to shift it to an Arduino, mainly because I had one I wanted to play with, and also I was thinking, same as you, of how you could have multiple programs. I used to have a sound machine that had brain wave frequencies embedded in the programs, and I really liked it until the day it died. I just wanted to thank you for all the info you have posted here, on other forums, and your github site...I was able to compile and upload and prototype the circuit within a half hour (most of that time spent digging for parts) thanks to you!
Just wanted to give you guys props and thanks for sharing!
GregW
Re: Brain Machine
Postby maltman23 » Fri Apr 22, 2011 10:03 am
Glad you got yours up and running. If you have any interesting results, please share your experiences.
Mitch.
maltman23
Re: Brain Machine
Postby gr33nman » Fri Apr 22, 2011 11:01 am
GregW wrote:I just got an Uno as well so I was pretty excited to come across this topic!...
GregW,
I'm glad it worked on the first try. Excellent. If you create some new programs, post them here or PM me, and I'll put them in the github library.
Chris
gr33nman
Re: Brain Machine
Postby drdavel » Wed Feb 15, 2012 8:32 am
I tried compiling this with arduino-1.0. Tone.cpp complained about digitalWrite not being defined. Editing #include <Arduino.h> and deleting #include <wiring.h> ( which does not seem to be present in the latest arduino-1.0 ) in Tone.cpp , gave a compile with no complaints.
Now to try out everything with the program!
David
drdavel
Return to Other Adafruit products
Users browsing this forum: Google [Bot] and 5 guests
New Products [102]
LEDs[109]
Cables[60]
