Microtouch: sensitive or buggy?
Postby raygeeknyc » Sat Feb 26, 2011 7:26 pm
Hi
I just received and powered up my Microtouch v.2.4 and it seems that the Touchscreen is a bit buggy - If I launch the paint app, I'm treated to a few large dots at the top and while I can press and paint, it seems that there are phantom presses causing other strokes to appear.
I ran the callibrate app and then the Hw Test. The HwTest shows coordinates even when I am not pressing the screen, sometimes it is the last coordinates I pressed but if I just sit and watch it will beginf to flash a series of X and Y coordinates but not that it is being pressed.
It's possible that this is a firmware or other known issue, so I figured I'd check here before declaring it defective.
Anyone?
raygeeknyc
Re: Microtouch: sensitive or buggy?
Postby adafruit » Mon Feb 28, 2011 3:57 pm
are you pressing down on the glass when holding it? make sure you hold it by the plastic
Postby raygeeknyc » Tue Mar 01, 2011 11:50 pm
No I am not making contact with the glass at all - it's resting on the board, that on my hand
raygeeknyc
Postby adafruit » Wed Mar 02, 2011 8:37 am
can you have it lying on the table flat with the pcb out to the side not underneath (not sure if thats what you mean)
Postby raygeeknyc » Sat Mar 05, 2011 12:13 pm
It's not, but I've tried that now as well - no better - well actually it's worse :( - the touchscreen is completely unresponsive in that position. I'm guessing that there are some loose connections somewhere in the arrangement.
raygeeknyc
Users browsing this forum: arbj, Google [Bot], mibignistinly and 22 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
