LiquidTWI: High-performance LCD library for I2C Backpack Module
- 1rj
Re: LiquidTWI: High-performance LCD library for I2C Backpack Module
PS: I did want to thank you for pointing out the potentiometer on the backpack. I didn't realize that it was there but now do. Although I could see the blocks very well. After I decide what to do with the arduino - I will definitely test the backpack potentiometer if I have a problem. Thanks again.
- 1rj
I'm using the "Hello World" I2C (not the TWI) and verified the slave address of the backpack and changed the LCD display info to reflect my 20x4 LCD: "4, 20". I haven't ever seen "Hello World" since trying to start the I2c.
- IMG_5489.jpg (51.26 KiB) Viewed 4276 times
- 1rj
The arduino micro-controller is now working and flashing lights as it should be. I posted the pics to see if if anyone can help - thanks
I see that that board is a bit different from that distributed by adafruit.
If that board uses the PCF8574 ASIC, give the New LiquidCristal library a shot. You can download it from: https://bitbucket.org/fmalpartida/new-l ... /wiki/Home
Also check that the I2C SCL and SCK are not swapped around.
Hope it helps.
Hope it helps.
- engineer
Just a shot here... try untwisting the all of the wires, especially the data and clock wires between the arduino and the lcd backpack. You may be getting some crosstalk between the two signals...
- bghobby
It appears that the library will no longer compile under Arduino 1.0. I believe the problem to be that the read(), print() and write() methods in the Stream class have been changed to return a variable of type "size_t" whereas previously these returned a "void". I would assume that the classes used in this library that have these methods are all subclasses of Stream and therefore a definition needs to be changed somewhere, perhaps in the .h file (although I don't have time right now to look through the library source code). If I understand this correctly (from the Arduino 1.0 release notes, that is), then the actual code that uses these methods will not change, since there was never a presumption of a return value. However, the C++ compiler seems to complain when it thinks you are trying to override a method that returned a value with one that returns a void.
I would like to request that the developer of this EXCELLENT library please update it for Arduino 1.0. My application could not tolerate the slowness of the Adafruit LCD-I2C library; this library is more than 10x faster and quite necessary in my application where the Arduino must read various inputs at least every few milliseconds.
Thanks.
Thanks.
- 1rj
Hi - Had hand surgery so unable to get back here till now. I've started all over with everything again. I think the problem could be the jumper in the backpack. The data sheet says that it comes set for serial rather than i2c. I'm having trouble finding it and the data sheet doesn't say or show where it is. I have the i2c serial backpack from web4robot.com 4x20 LCD from adafruit. Here is a link to the data sheet which shows a picture of the backpack if anyone might help. http://web4robot.com/files/SerialLCDCtrl.pdf. Thanks again for you help. I'm following all the suggestions but still no luck.
hi there, to be clear, you're having difficulty using a product we dont sell use or support. for technical support for this product we suggest contacting the distributor. they'll have their own tech support forums! thanks1RJ wrote:Hi - Had hand surgery so unable to get back here till now. I've started all over with everything again. I think the problem could be the jumper in the backpack. The data sheet says that it comes set for serial rather than i2c. I'm having trouble finding it and the data sheet doesn't say or show where it is. I have the i2c serial backpack from web4robot.com 4x20 LCD from adafruit. Here is a link to the data sheet which shows a picture of the backpack if anyone might help. http://web4robot.com/files/SerialLCDCtrl.pdf. Thanks again for you help. I'm following all the suggestions but still no luck.
Where can I download the library? I tried this link from the first post:
LiquidTWI library is attached to this post, also mirrored here: http://hostfile.org/LiquidTWI.rar
...without success. I could also not see it attached anywhere on the post.
Yeah... Hostfile died some months ago and notifications (from people like you) about what links I've posted around the 'net that are now dead are slowly trickling in. But like Hostfile, LiquidTWI is somewhat outdated too... several reports about it being incompatible with Arduino v1.0+ kinda made me bummed a bit. All my Arduino stuff is in a box I haven't touched in months... I'm kinda hoping someone else would pick up the torch and run with it. But I'll dig up the archived file and post it on my Dropbox where it'll stay active forever. Just a sec... I'll update the original post in a minute.
("we are unable to confirm that this post is not spam - please complete the captcha below"?! Are you for freakin' real?!)
Wait, how did you miss this??
- lungstruck
It appears someone did, forum user Stephanie posted an updated LiquidTWI in another thread. It's available here:several reports about it being incompatible with Arduino v1.0+ kinda made me bummed a bit. All my Arduino stuff is in a box I haven't touched in months... I'm kinda hoping someone else would pick up the torch and run with it.
https://github.com/Stephanie-Maks/Arduino-LiquidTWI
I tested it under 1.0.3 and it work great. It also includes kch's patch which is a nice bonus.
either one doen't work on 1.0.5....
- lungstruck
What doesn't work? I just installed Arduino 1.0.5, added Stephanie Mak's updated LiquidTWI to my libraries and ran the included Hello World and PerfTest examples w/o any problem.either one doen't work on 1.0.5....
Hello again!
FINALLY dug out my i2c LCD board and played around with this thing. The compile errors were caused by two things: a name change in Wire (from send() to write()), and a format change for the write() function. In order for LiquidTWI's write() to work, it needs to mesh up with Print's write(), which now returns a size_t instead of nothing (void). A couple compiler problems, that's it. /facepalm
Also bug-fixed (maybe...) the occasional initialization glitch by increasing the start-up delay to 100ms. That's only done once, so it shouldn't affect performance at all.
Finally, this thing is ready for the latest Arduino IDE. Sorry it took so long...
See first post for updated version and information.
