TTL Serial Camera doesn't seem to be getting power
Re: TTL Serial Camera doesn't seem to be getting power
Postby dpickem » Tue Jun 05, 2012 7:40 pm
I am having the same problem with this TTL serial camera. The pictures below show the setup that I have tested with the exact same model of the camera of a friend, which worked just fine. My camera however produces a jagged looking, distorted black and white picture.
photo 1.JPG (479.22 KiB) Viewed 934 times
photo 2.JPG (481.63 KiB) Viewed 934 times
dpickem
Postby adafruit » Tue Jun 05, 2012 8:56 pm
to clarify, is that camera you are testing from Adafruit or from a friend?
Are you using a PAL or NTSC television?
Postby dpickem » Tue Jun 05, 2012 10:09 pm
The camera that is shown in the picture and that is not working is my own camera (from Adafruit). I just used my friends camera to test the setup and compare the image quality. I have tried both PAL and NTSC and fed it into my laptop with the following product from Amazon (http://www.amazon.com/EasyCAP-DC60-Crea ... B002H3BSCM). Both formats resulted in the same image quality.
dpickem
Postby adafruit » Tue Jun 05, 2012 10:15 pm
have you tried using the photography functions?
can you take a screencap of what the image looks like? have you tried also a plain TV?
Postby dpickem » Wed Jun 06, 2012 8:41 am
I have not tried the photography functions yet, nor have I used the camera with a TV. This is how the camera image looks like:
dpickem
Postby john444 » Wed Jun 06, 2012 12:41 pm
Hi D,
You photo looks as if there is ripple from the power supply.
John
john444
Postby dpickem » Thu Jun 07, 2012 9:51 am
The power is supplied through the regulated 5V output from an Arduino Uno. I have checked the voltage output with an oscilloscope and there is no noticable ripple. Also the exact same setup worked with the exact same camera from a friend.
dpickem
Postby john444 » Thu Jun 07, 2012 1:33 pm
If the oscilloscope is not showing it then that blows the ripple theory.
dpickem wrote:Also the exact same setup worked with the exact same camera from a friend.
Since the setup worked OK with a different camera then the problem seems to be in the existing camera.
john444
Postby adafruit » Thu Jun 07, 2012 5:33 pm
we could try replacing the camera, although that may not fix the problem. email support@adafruit to replace it
Previous
Users browsing this forum: No registered users and 4 guests
New Products [103]
LEDs[109]
Cables[61]
