TTL Serial Camera doesn't seem to be getting power
Breakout boards, sensors, Drawdio, Game of Life, other Adafruit kits, etc.
Postby gryphonbot » Tue Jan 10, 2012 8:54 pm
I don’t think my TTL serial camer is getting power. I connect it to
my Arduino’s 5V and GND pins, but nothing. I get no image on the
composite video connection to my TV either. My soldering looks fine, but just to be sure I even re-did the solder for 5V and GND and still get nothing. Do you
think the unit is bad? Hoping you can help. 8)
gryphonbot
Re: TTL Serial Camera doesn't seem to be getting power
Postby gryphonbot » Wed Jan 11, 2012 9:45 pm
Here is a photo of my connections.
gryphonbot
Postby adafruit_support_bill » Thu Jan 12, 2012 6:17 am
The soldering does look fine there. And the other ends of the wires are connected as below for NTSC video output?
Postby gryphonbot » Sat Jan 14, 2012 12:50 pm
I think so.
gryphonbot
Postby adafruit_support_bill » Sat Jan 14, 2012 1:37 pm
Not sure what the pinouts are on the RCA jack in your photo. Make sure that the black wire has continuity to the outer shield and the yellow wire to the center contact on the jack.
Postby gryphonbot » Sat Jan 14, 2012 3:49 pm
The wires are connected to the proper pins.
gryphonbot
Postby adafruit_support_bill » Sat Jan 14, 2012 4:09 pm
OK then. Contact support@adafruit.com about a replacement and include a link to this thread in your message.
Postby gryphonbot » Thu Jan 19, 2012 7:13 pm
I received my replacement camera today. Soldered it up and it worked right away. Thanks for sending it out so fast!
gryphonbot
Postby Row » Fri May 25, 2012 9:50 am
I received this camera and I am having similar issues. I get no output video from the composite video. Below are images of my soldering job.
Camera1
photo 1.JPG (252.63 KiB) Viewed 1154 times
Camer2
photo 2.JPG (304.29 KiB) Viewed 1154 times
Row
Postby adafruit_support_bill » Fri May 25, 2012 10:04 am
Can you show how you have the other ends of those wires connected?
Postby Row » Fri May 25, 2012 10:14 am
I have tested that the RCA jack is wired correctly with a separate video source and I know that the power source works and puts out 5V. Not sure why I don't get an image.
Camera connection
Row
Postby adafruit_support_bill » Fri May 25, 2012 10:58 am
Those connections look fine. Contact support@adafruit.com with a link to this thread and ask for a replacement camera.
Postby adafruit » Fri May 25, 2012 12:22 pm
that breadboard might have a split power rail, move the power wires to right next to the regulator.
Postby Row » Fri May 25, 2012 12:50 pm
The power supply gives power to both rails. I have tested with a multimeter that the camera is receiving 5V.
Row
Next
Return to Other Adafruit products
Users browsing this forum: No registered users and 10 guests
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
