Requires 5-9VDC @ 1.5Amp power supply
char
*serverName = "search.twitter.com",
// queryString can be any valid Twitter API search string, including
// boolean operators. See https://dev.twitter.com/docs/using-search
// for options and syntax. Funny characters do NOT need to be URL
// encoded here -- the sketch takes care of that.
*queryString = "from:Adafruit",
lastId[21], // 18446744073709551615\0 (64-bit maxint as string)
timeStamp[32], // WWW, DD MMM YYYY HH:MM:SS +XXXX\0
fromUser[16], // Max username length (15) + \0
msgText[141], // Max tweet length (140) + \0
name[11], // Temp space for name:value parsing
value[141]; // Temp space for name:value parsing // this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
extern int __bss_end;
extern int *__brkval;
int free_memory;
if((int)__brkval == 0) {
free_memory = ((int)&free_memory) - ((int)&__bss_end);
else {
free_memory = ((int)&free_memory) - ((int)__brkval);
return free_memory;
Support has been added for printing strings stored in flash (program
memory) rather than RAM. Wrap double-quoted strings in F() to indicate
that they should be stored in flash, e.g. Serial.print(F("hello world")).
avrdude: stk500_getsync(): not in sync: resp=0x00Return to Other Adafruit products
Users browsing this forum: No registered users and 8 guests
