Thank you so much for your help pburgess, it woks perfectly now.
As some kind of thankyou I've done as much of the mapping as I could, following the example you showed me, with the wiki-link you sendt
Have no idea how to add it back to the repository as you suggest (it could probably also be solved more elegantly than this list?), but here is at least something that seems to work (havent done very much testing on it though, so no guarantees from me:). Do feel free to modify/republish/whatever
I also have an xls spreadsheet that I used to generate this in in case you/someone would want to implement it better (for example some kind of matrix instead of this list
) where each value has its own cell hopefully making it easier to copy/paste? If you're interested I'll put it somwhere you can find it
again, thank you very much!
Best regards
Anders
- Code: Select all
int unidecode(byte len) {
int c, v, result = 0;
while(len--) {
if((c = timedRead()) < 0) return -1; // Stream timeout
if ((c >= '0') && (c <= '9')) v = c - '0';
else if((c >= 'A') && (c <= 'F')) v = 10 + c - 'A';
else if((c >= 'a') && (c <= 'f')) v = 10 + c - 'a';
else return '-'; // garbage
result = (result << 4) | v;
switch(result) {
// control and basic latin that is not handeled elsewhere
case 0x003C: return 0x3C; // < Less-than sign
case 0x003E: return 0x3E; // > Greater-than sign
case 0x007B: return 0x7B; // { Left Curly Bracket
case 0x007D: return 0x7D; // } Right Curly Bracket
//CP437 (printer charset) characters not handeled elsewhere
//0x8X
case 0x00C7: return 0x80; // Ç Latin Capital letter C with cedilla
case 0x00FC: return 0x81; // ü Latin Small Letter U with diaeresis
case 0x00E9: return 0x82; // é Latin Small Letter E with acute
case 0x00E2: return 0x83; // â Latin Small Letter A with circumflex
case 0x00E4: return 0x84; // ä Latin Small Letter A with diaeresis
case 0x00E0: return 0x85; // à Latin Small Letter A with grave
case 0x00E5: return 0x86; // å Latin Small Letter A with ring above
case 0x00E7: return 0x87; // ç Latin Small Letter C with cedilla
case 0x00EA: return 0x88; // ê Latin Small Letter E with circumflex
case 0x00EB: return 0x89; // ë Latin Small Letter E with diaeresis
case 0x00E8: return 0x8A; // è Latin Small Letter E with grave
case 0x00EF: return 0x8B; // ï Latin Small Letter I with diaeresis
case 0x00EE: return 0x8C; // î Latin Small Letter I with circumflex
case 0x00EC: return 0x8D; // ì Latin Small Letter I with grave
case 0x00C4: return 0x8E; // Ä Latin Capital letter A with diaeresis
case 0x00C5: return 0x8F; // Å Latin Capital letter A with ring above
//0x9X
case 0x00C9: return 0x90; // É Latin Capital letter E with acute
case 0x00E6: return 0x91; // æ Latin Small Letter Æ
case 0x00C6: return 0x92; // Æ Latin Capital letter Æ
case 0x00F4: return 0x93; // ô Latin Small Letter O with circumflex
case 0x00F6: return 0x94; // ö Latin Small Letter O with diaeresis
case 0x00F2: return 0x95; // ò Latin Small Letter O with grave
case 0x00FB: return 0x96; // û Latin Small Letter U with circumflex
case 0x00F9: return 0x97; // ù Latin Small Letter U with grave
case 0x00FF: return 0x98; // ÿ Latin Small Letter Y with diaeresis
case 0x00D6: return 0x99; // Ö Latin Capital letter O with diaeresis
case 0x00DC: return 0x9A; // Ü Latin Capital Letter U with diaeresis
case 0x00A2: return 0x9B; // ¢ Cent sign
case 0x00A3: return 0x9C; // £ Pound sign
case 0x00A5: return 0x9D; // ¥ Yen sign
//case 0x0000: return 0x9E; // ₧ couldn't find unicode equivalent
case 0x0192: return 0x9F; // ƒ Latin Small Letter F with hook
//0xAX
case 0x00E1: return 0xA0; // á Latin Small Letter A with acute
case 0x00ED: return 0xA1; // í Latin Small Letter I with acute
case 0x00F3: return 0xA2; // ó Latin Small Letter O with acute
case 0x00FA: return 0xA3; // ú Latin Small Letter U with acute
case 0x00F1: return 0xA4; // ñ Latin Small Letter N with tilde
case 0x00D1: return 0xA5; // Ñ Latin Capital letter N with tilde
case 0x00AA: return 0xA6; // ª Feminine Ordinal Indicator
case 0x00BA: return 0xA7; // º Masculine ordinal indicator
case 0x00BF: return 0xA8; // ¿ Inverted Question Mark
//case 0x0000: return 0xA9; // ⌐ couldn't find unicode equivalent
case 0x00AC: return 0xAA; // ¬ Not sign
case 0x00BD: return 0xAB; // ½ Vulgar fraction one half
case 0x00BC: return 0xAC; // ¼ Vulgar fraction one quarter
case 0x00A1: return 0xAD; // ¡ Inverted Exclamation Mark
case 0x00AB: return 0xAE; // « Left-pointing double angle quotation mark
case 0x00BB: return 0xAF; // » Right-pointing double angle quotation mark
//0xBX
case 0x2591: return 0xB0; // ░ Light shade
case 0x2592: return 0xB1; // ▒ Medium shade
case 0x2593: return 0xB2; // ▓ Dark shade
case 0x2233: return 0xB3; // │ Mathematical operator
case 0x22A3: return 0xB4; // ┤ Mathematical operator
//case 0x22: return 0xB5; // ╡ couldn't find unicode equivalent
//case 0x22: return 0xB6; // ╢ couldn't find unicode equivalent
//case 0x22: return 0xB7; // ╖ couldn't find unicode equivalent
//case 0x22: return 0xB8; // ╕ couldn't find unicode equivalent
//case 0x22: return 0xB9; // ╣ couldn't find unicode equivalent
case 0x2225: return 0xBA; // ║ Mathematical operator
//case 0x22: return 0xBB; // ╗ couldn't find unicode equivalent
//case 0x22: return 0xBC; // ╝ couldn't find unicode equivalent
//case 0x22: return 0xBD; // ╜ couldn't find unicode equivalent
//case 0x22: return 0xBE; // ╛ couldn't find unicode equivalent
//case 0x22: return 0xBF; // ┐ couldn't find unicode equivalent
//0xCX
//case 0x0000: return 0xC0; // └ couldn't find unicode equivalent
case 0x22A5: return 0xC1; // ┴ Mathematical operator
case 0x22A4: return 0xC2; // ┬ Mathematical operator
case 0x22A6: return 0xC3; // ├ Mathematical operator
case 0x2212: return 0xC4; // ─ Mathematical operator
//case 0x0000: return 0xC5; // ┼ couldn't find unicode equivalent
case 0x22A7: return 0xC6; // ╞ Mathematical operator
case 0x22A9: return 0xC7; // ╟ Mathematical operator
//case 0x0000: return 0xC8; // ╚ couldn't find unicode equivalent
//case 0x0000: return 0xC9; // ╔ couldn't find unicode equivalent
//case 0x0000: return 0xCA; // ╩ couldn't find unicode equivalent
//case 0x0000: return 0xCB; // ╦ couldn't find unicode equivalent
//case 0x0000: return 0xCC; // ╠ couldn't find unicode equivalent
//case 0x0000: return 0xCD; // ═ couldn't find unicode equivalent
//case 0x0000: return 0xCE; // ╬ couldn't find unicode equivalent
//case 0x0000: return 0xCF; // ╧ couldn't find unicode equivalent
//0xDX
//case 0x0000: return 0xD0; // ╨ couldn't find unicode equivalent
//case 0x0000: return 0xD1; // ╤ couldn't find unicode equivalent
//case 0x0000: return 0xD2; // ╥ couldn't find unicode equivalent
//case 0x0000: return 0xD3; // ╙ couldn't find unicode equivalent
//case 0x0000: return 0xD4; // ╘ couldn't find unicode equivalent
//case 0x0000: return 0xD5; // ╒ couldn't find unicode equivalent
//case 0x0000: return 0xD6; // ╓ couldn't find unicode equivalent
//case 0x0000: return 0xD7; // ╫ couldn't find unicode equivalent
//case 0x0000: return 0xD8; // ╪ couldn't find unicode equivalent
//case 0x0000: return 0xD9; // ┘ couldn't find unicode equivalent
//case 0x0000: return 0xDA; // ┌ couldn't find unicode equivalent
case 0x2588: return 0xDB; // █ Full block
case 0x2584: return 0xDC; // ▄ Lower half block
case 0x258C: return 0xDD; // ▌ Left half block
case 0x2590: return 0xDE; // ▐ Right half block
case 0x2580: return 0xDF; // ▀ Upper half block
//0xEX
case 0x03B1: return 0xE0; // α Greek Small Letter Alpha
case 0x03B2: return 0xE1; // ß Greek Small Letter Beta
case 0x0393: return 0xE2; // Γ Greek Capital Letter Gamma
case 0x03C0: return 0xE3; // π Greek Small Letter Pi
case 0x03A3: return 0xE4; // Σ Greek Capital Letter Sigma
case 0x03C3: return 0xE5; // σ Greek Small Letter Sigma
case 0x00B5: return 0xE6; // µ Micro sign
case 0x03A4: return 0xE7; // τ Greek Capital Letter Tau
case 0x03A6: return 0xE8; // Φ Greek Capital Letter Phi
case 0x0398: return 0xE9; // Θ Greek Capital Letter Theta
case 0x03A9: return 0xEA; // Ω Greek Capital Letter Omega
case 0x03B4: return 0xEB; // δ Greek Small Letter Delta
case 0x221E: return 0xEC; // ∞ Mathematical operator
case 0x03C6: return 0xED; // φ Greek Capital Letter Phi
case 0x03B5: return 0xEE; // ε Greek Small Letter Epsilon
case 0x2229: return 0xEF; // ∩ Mathematical operator
//0xFX
case 0x2261: return 0xF0; // ≡ Mathematical operator
case 0x00B1: return 0xF1; // ± Plus-minus sign
case 0x2265: return 0xF2; // ≥ Mathematical operator
case 0x2264: return 0xF3; // ≤ Mathematical operator
//case 0x22: return 0xF4; // ⌠ Mathematical operator
//case 0x22: return 0xF5; // ⌡ Mathematical operator
case 0x00F7: return 0xF6; // ÷ Mathematical operator
case 0x2248: return 0xF7; // ≈ Mathematical operator
case 0x00B0: return 0xF8; // ° Degree symbol
case 0x2219: return 0xF9; // ∙ Mathematical operator
case 0x22C5: return 0xFA; // · Mathematical operator
case 0x221A: return 0xFB; // √ Mathematical operator
//case 0x22: return 0xFC; // ⁿ
case 0x00B2: return 0xFD; // ² Superscript two
case 0x2596: return 0xFE; // ■ Mathematical operator
return '-';
