- The first picture shows the project when it is plugged into the USB on my laptop
- This next picture is when I remove the USB and plug in the 6xAA power supply
- Closeup of the screen when the 6xAA power supply is plugged in
- When the GPS wiring is removed the shield's backlight appears to work again
- Back of the LCD Shield
- Closeup of the soldering on the GPS breakout
- Closeup of the top of the LCD Shield frontWhen the GPS wiring is removed the shield's backlight appears to work again
- GPS removed from breadboard, Backlight on
- TX and RX disconnected, Backlight on
- TX disconnected, Backlight on
- RX disconnected, Backlight on#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
#include <Adafruit_GPS.h>
#if ARDUINO >= 100
#include <SoftwareSerial.h>
#else
#include <NewSoftSerial.h>
#endif
#if ARDUINO >= 100
SoftwareSerial mySerial(4, 2);
#else
NewSoftSerial mySerial(4, 2);
#endif
Adafruit_GPS GPS(&mySerial);
#define GPSECHO true
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
void setup()
//LCD Setup
Serial.begin(115200);
lcd.begin(16, 2);
lcd.setBacklight(RED);
//GPS Setup
GPS.begin(9600);
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
useInterrupt(true);
delay(1000);
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
char c = GPS.read();
if (GPSECHO)
if (c) UDR0 = c;
void useInterrupt(boolean v) {
if (v) {
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
usingInterrupt = true;
} else {
TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
void loop() // run over and over again
if (! usingInterrupt) {
if (GPSECHO)
if (c) UDR0 = c;
if (GPS.newNMEAreceived()) {
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
if (timer > millis()) timer = millis();
if (millis() - timer > 2000) {
timer = millis(); // reset the timer
lcd.setCursor(0, 0);
lcd.print("Fix: "); lcd.print((int)GPS.fix);
lcd.print(" Qual: "); lcd.print((int)GPS.fixquality);
if (GPS.fix) {
lcd.setCursor(0, 1);
lcd.print("Lat: ");
lcd.print(GPS.latitude, 4); Serial.print(GPS.lat);
delay(1000);
lcd.print("Lon: ");
lcd.print(GPS.longitude, 4); Serial.println(GPS.lon);
Example code for the Adafruit RGB Character LCD Shield and Library
This code displays text on the shield, and also reads the buttons on the keypad.
When a button is pressed, the backlight changes color.
// include the library code:
#include <Wire.h>
// The shield uses the I2C SCL and SDA pins. On classic Arduinos
// this is Analog 4 and 5 so you can't use those for analogRead() anymore
// However, you can connect other I2C sensors to the I2C bus and share
// the I2C bus.
// These #defines make it easy to set the backlight color
#define RED 0x1
#define YELLOW 0x3
#define GREEN 0x2
#define TEAL 0x6
#define BLUE 0x4
#define VIOLET 0x5
#define WHITE 0x7
// Debugging output
Serial.begin(9600);
// set up the LCD's number of rows and columns:
lcd.begin(16, 2);
// Print a message to the LCD. We track how long it takes since
// this library has been optimized a bit and we're proud of it :)
int time = millis();
lcd.print("Hello, world!");
time = millis() - time;
Serial.print("Took "); Serial.print(time); Serial.println(" ms");
lcd.setBacklight(BLUE);
uint8_t i=0;
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
// print the number of seconds since reset:
lcd.print(millis()/1000);
uint8_t buttons = lcd.readButtons();
if (buttons) {
lcd.clear();
lcd.setCursor(0,0);
if (buttons & BUTTON_UP) {
lcd.print("UP ");
if (buttons & BUTTON_DOWN) {
lcd.print("DOWN ");
lcd.setBacklight(YELLOW);
if (buttons & BUTTON_LEFT) {
lcd.print("LEFT ");
lcd.setBacklight(GREEN);
if (buttons & BUTTON_RIGHT) {
lcd.print("RIGHT ");
lcd.setBacklight(TEAL);
if (buttons & BUTTON_SELECT) {
lcd.print("SELECT ");
lcd.setBacklight(VIOLET);
Return to Other Adafruit products
Users browsing this forum: No registered users and 6 guests
