Does Miniature WiFi support RFMON/Monitor mode?
PJman
Post by PJman »
I want build a compact standalone wifi sniffer with my new Beaglebone. I came across the new Miniature WiFi module from adafruit and wanted to ask, does anyone know if it supports RFMON/Monitor mode? Has anyone tried using it with Aircrack-ng?
Also, any recommendations on which USB WiFi module works best with Beaglebone + Aircrack-ng?
Re: Does Miniature WiFi support RFMON/Monitor mode?
Post by adafruit »
You'll need to figure out which chipsets support it, this is an RTL8192. It works great with the Bone but not sure what RFMON or Aircrack is
PJman
Post by PJman »
adafruit, thanks for the quick response! I guess the best way would be to test it out.
Do you have any specs on the received signal strength (in db?).
Post by adafruit »
Everything we know is in the technical tab, we'll try to get an external-antenna version that works, but unfortunately we found that not all USB adapters were friendly with the Bone, this one was!
