Does Miniature WiFi support RFMON/Monitor mode?
by PJman on Mon May 07, 2012 4:23 pm
I want build a compact standalone wifi sniffer with my new Beaglebone. I came across the new Miniature WiFi module from adafruit and wanted to ask, does anyone know if it supports RFMON/Monitor mode? Has anyone tried using it with Aircrack-ng?
Also, any recommendations on which USB WiFi module works best with Beaglebone + Aircrack-ng?
PJman
Re: Does Miniature WiFi support RFMON/Monitor mode?
by adafruit on Mon May 07, 2012 5:23 pm
You'll need to figure out which chipsets support it, this is an RTL8192. It works great with the Bone but not sure what RFMON or Aircrack is
by PJman on Mon May 07, 2012 5:50 pm
adafruit, thanks for the quick response! I guess the best way would be to test it out.
Do you have any specs on the received signal strength (in db?).
PJman
by adafruit on Mon May 07, 2012 8:30 pm
Everything we know is in the technical tab, we'll try to get an external-antenna version that works, but unfortunately we found that not all USB adapters were friendly with the Bone, this one was!
