Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
water flow meter
water flow meter
by Nour on Fri Jul 06, 2012 12:54 pm
I’m interested in one of your product (Liquid Flow Meter, Brass ½’’ NTP)
> product ID #833, but I do not have any tools or electronic gadget to display
> the water flow through the pip. So, do you provide an LCD display that will
> display on any LCD the water flow? I do need 4-6 of these sets. So, the
> idea here is to plug the brass piece in line with my pool water supply and
> read the water flow on the LCD display. The accuracy is not that critical
> and the rate will be from 1-20 L/M (litter per minute)
Nour
Re: water flow meter
by adafruit_support_bill on Fri Jul 06, 2012 1:15 pm
We don't have a 'plug & play' solution. But we do have all the parts you need to build one. If you are OK with a bit of soldering & a little programming, we can help you put together a system.
by Nour on Fri Jul 06, 2012 3:14 pm
adafruit_support wrote:We don't have a 'plug & play' solution. But we do have all the parts you need to build one. If you are OK with a bit of soldering & a little programming, we can help you put together a system.
I'm OK with that. What materials are needed and what is the cost for each iteam. I do have soldering tools but needs ehlp in programming. Thanks
Nour
by adafruit_support_bill on Fri Jul 06, 2012 3:47 pm
This is kind of a general list.
The Flow meters you have already found: https://www.adafruit.com/products/833
You will also need a microprocessor of some sort. An Arduino UNO is ahbout the easiest one to program: http://www.adafruit.com/products/50
You will also need a power supply. This is a good one to start with: http://www.adafruit.com/products/63
The sample code for the flow meter works is written for the UNO and a basic LCD character display. http://www.adafruit.com/products/198 However, for multiple meters, you may want to go with a larger display such as this one: http://www.adafruit.com/products/498
The "backpack" simplifies display wiring and frees up pins for more sensors: http://www.adafruit.com/products/292
Since this is a pool application, You may also want to check out our range of waterproof enclosures, cables & connectors.
