I just received the MPL115A2-IC2 breakout from you and the sample "getpressure" sketch works above ~22.6*C, but below this I'm getting strange readings like -12041.0*C. Is there a narrow usable range for this sensor or do you think something else if going on?
Here is a sample from the serial monitor as it cools off a bit:
Temp (*C): 23.7 *C
Pressure (kPa): 102.2354 kPa
Temp (*C): 23.5 *C
Pressure (kPa): 102.1922 kPa
Temp (*C): 23.3 *C
Temp (*C): 23.3 *C
Pressure (kPa): 102.2985 kPa
Temp (*C): 23.3 *C
Pressure (kPa): 102.1489 kPa
Temp (*C): 23.1 *C
Temp (*C): 22.9 *C
Pressure (kPa): 102.2747 kPa
Temp (*C): 23.1 *C
Temp (*C): 22.9 *C
Pressure (kPa): 102.2313 kPa
Temp (*C): 22.9 *C
Temp (*C): 22.6 *C
Pressure (kPa): -2694.5083 kPa
Temp (*C): 22.6 *C
Temp (*C): -12035.9 *C
Pressure (kPa): -2697.3217 kPa
Temp (*C): -12036.1 *C
Pressure (kPa): -2700.0920 kPa
Pressure (kPa): -2697.4084 kPa
Temp (*C): -12036.5 *C
Pressure (kPa): -2700.1787 kPa
Temp (*C): -12036.7 *C
I ordered 2 of these and get the same results with each.
Thanks for your help
MPL115A2 Pressure and Temp Breakout - bad readings below 22*C
- kellyf
Re: MPL115A2 Pressure and Temp Breakout - bad readings below 22*C
Hmmm. In the library, near the end of Adafruit_MPL115A2.cpp, there is the following section of code:
Un-comment the "Serial.print" line. Run your test again and post the output.
pressure = ((i2cread() << 8) | i2cread()) >> 6;
temp = ((i2cread() << 8) | i2cread()) >> 6;
//Serial.print("t = "); Serial.println(temp, HEX);
float centigrade = temp;
centigrade -= 498;
centigrade /= -5.35;
centigrade += 25;
- adafruit_support_rick
There's something about the library I don't quite understand, but I don't have one these sensors here to test with.
If you would, go into the library, and in function readCoefficients, comment out the following lines
and replace them with an assignment of 0 to _mpl115a2_c12:
Run that and see if your anomalous behavior goes away.
_mpl115a2_c12 = (float)c12coeff;
_mpl115a2_c12 /= 4194304.0;
// _mpl115a2_c12 = (float)c12coeff;
// _mpl115a2_c12 /= 4194304.0;
_mpl115a2_c12 = 0.0;
- rberni
Having the exact same problem, did as suggested with no change. Any other ideas?
Can you try uncommenting the debug output as adafruit_support suggested above?
- sellensr
I have the same problem and uncommented the line. It looks like temp is wrapping to a negative value (FE00). The bit shifting seems to be failing as a translation. Casting the result to a longer data type (e.g. long or unsigned or uint16_t) before the left shift makes room for things to work out. You need to change these two lines in both the pressure and temperature functions in the library from
pressure = ((i2cread() << | i2cread()) >> 6;
temp = ((i2cread() << | i2cread()) >> 6;
to
pressure = (((uint16_t)i2cread() << | i2cread()) >> 6;
temp = (((uint16_t)i2cread() << | i2cread()) >> 6;
I trust somebody from adafruit is watching and the mod will find its way into the posted library.
I may have just learned how to fork a github repository and make an update at https://github.com/sellensr/Adafruit_MPL115A2. At least I hope I didn't break anything
Old Output:
t = 1FF
Temp (*C): 22.6 *C
Pressure (kPa): 101.4271 kPa
t = 1FE
Temp (*C): 22.8 *C
t = 1FE
Temp (*C): 22.8 *C
Pressure (kPa): 101.2062 kPa
t = 1FF
Temp (*C): 22.6 *C
Pressure (kPa): 101.3800 kPa
t = FE00
Pressure (kPa): 101.3166 kPa
t = 1FF
Temp (*C): 22.6 *C
Pressure (kPa): -2930.0664 kPa
t = 1FE
Temp (*C): 22.8 *C
t = 1FE
Temp (*C): 22.8 *C
Pressure (kPa): 101.1592 kPa
t = FE00
t = 1FF
Temp (*C): 22.6 *C
t = 1FE
Temp (*C): 22.8 *C
t = 1FF
Temp (*C): 22.6 *C
Pressure (kPa): 101.2696 kPa
t = 1FF
Temp (*C): 22.6 *C
t = 1FE
Temp (*C): 22.8 *C
Pressure (kPa): -2927.3835 kPa
t = 1FF
Temp (*C): 22.6 *C
t = 1FF
Temp (*C): 22.6 *C
t = 1FE
Temp (*C): 22.8 *C
t = FE00
to
Old Output:
t = 1FF
Temp (*C): 22.6 *C
t = 1FE
Temp (*C): 22.8 *C
t = 1FE
Temp (*C): 22.8 *C
t = 1FF
Temp (*C): 22.6 *C
t = FE00
t = 1FF
Temp (*C): 22.6 *C
t = 1FE
Temp (*C): 22.8 *C
t = 1FE
Temp (*C): 22.8 *C
t = FE00
t = 1FF
Temp (*C): 22.6 *C
t = 1FE
Temp (*C): 22.8 *C
t = 1FF
Temp (*C): 22.6 *C
t = 1FF
Temp (*C): 22.6 *C
t = 1FE
Temp (*C): 22.8 *C
t = 1FF
Temp (*C): 22.6 *C
t = 1FF
Temp (*C): 22.6 *C
t = 1FE
Temp (*C): 22.8 *C
t = FE00
If you post your fix as an issue to Github it will get onto our To-Do list.
- sellensr
I posted it to Github, along with another fix to retrieve both T and P on the same call. It shows up on the repository as an issue and a pull request. Let me know if I got the process right, as this is my first try uploading to Github.
Thanks. It's in the system now, so it won't fall off our radar.
