Is there a mechanical drawing for the 11" Panel Mount Ethernet Extension Cable? (http://adafruit.com/products/909)
The hole spacing is given, but I need to know the height, width and depth of the rubber boot as well.
Thanks.
Panel Mount Ethernet Extension Cable Mechanical Drawing
- adafruit_support_rick
Re: Panel Mount Ethernet Extension Cable Mechanical Drawing
Sorry We don't have that information.
- bekathwia
Hi Tyler,
I've measured the "boot" and added these dimensions to the tech specs tab on the product: http://adafruit.com/products/909
- jonathanw.diateam
Could we also have the dimensions of the Ethernet connector inside the boot? we would need these to laser cut the appropriate panel cutout.
Many thanks,
Jonathan
Many thanks,
Jonathan
That's a standard RJ-45. Here's the datasheet for a comparable connector from Molex.
DOES ANYONE KNOW WHO MAKES THIS FOR ADAFRUIT???
We have questions regarding CE and ROHS. Perhaps the original vendor can provide this info.
thanks for the post, there is not CE info supplied for this product from our factory partner.
Who is your factory partner
Our contracts with our suppliers forbid us from sharing the information with third parties. If you need specific CE and RoHS information, you'll need to contact another vendor like Molex or Amphenol and ask about comparable products.
- Matt29
I need a RoHS compliance certificate for this product ID 909.
Do you think that is possible? We order this part on Adafruit website, so our vendor is Adafruit.
Thanks.
Thanks.
hi! please check your spam folder, we have emailed the request in reply to your email today, we'll try to obtain a cert.
- splite
I'm going to order hundred enclosures to an industrial and I would like to use this panel mount extension.
Industrial are usually working with cut out drawing to set there machines. Could you provide such cut out drawing ? Currently it is impossible for anybody to use your product in an industrial manner...
Thank
Best regards,
Florian
Thank
Best regards,
Florian
- adafruit2
this is all we hvae right now
https://www.adafruit.com/images/product ... rawing.pdf
which is likely not really what you want :) we're asking the factory for a better dimensioned drawing
- splite
Thank for the new drawing but indeed the cut out drawing is missing.
I wait for an answer from your factory. They should be able to produce such document.
Regards,
Florian
Regards,
Florian
- stevesoto11
Still no cutout drawing for this panel mount connector? Kind of essential to be able to use it. Easy enough to give it a try and hope for the best, but shouldn't be that way. Especially when there is no real defined location of the holes. All we know is they are 24mm apart. Are they located at the centerline of the RJ45?
