Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
Outdoor Mounting for Hall effect sensor - US5881LUA (#158)
by SeaLyon on Thu Nov 15, 2012 10:03 am
I have an application where I need to mount some Hall effect sensors outdoors and I have very little room to work with. I'd like to find a mounting method that will result in the smallest package possible and be weatherproof. I was thinking about covering them in epoxy to provide a waterproof barrier. Any ideas about whether this might work? Any thoughts on the best method to create a small releasable form to encase the sensor in epoxy? Will epoxy limit the range of the sensor? If epoxy is not a good idea, any other options?
SeaLyon
Re: Outdoor Mounting for Hall effect sensor - US5881LUA (#158)
by adafruit_support_bill on Thu Nov 15, 2012 10:53 am
Be sure to use an epoxy rated for outdoor use. Marine epoxies are a good choice. For small things like hall sensors, I dip them in epoxy then apply heat-shrink. Epoxy should not affect the operation of the sensor.
by Aluman000 on Tue Dec 11, 2012 12:19 pm
You don't sell marine epoxy do you?
Aluman000
by adafruit_support_bill on Tue Dec 11, 2012 12:40 pm
Sorry, no. Sugru would probably work well in this application too. But I haven't tried it.
http://www.adafruit.com/products/436
by dmpyron on Sat Dec 15, 2012 4:31 pm
Aluman000 wrote:You don't sell marine epoxy do you?
If you live anywhere near a navigable body of water there's probably some sort of store that carries it. Failing that, I know West Marine carries it in 8 oz cans. Note that shipping is just this side of obscene.
dmpyron
