Solenoid circuit question
by dustynrobots on Mon Dec 03, 2012 10:18 pm
So I have a small solenoid from Adafruit and I hooked it up as in the diagram here and it works:
http://www.arduino.cc/playground/upload ... driver.pdf
However, I first had it hooked up with the solenoid and the transistor order reversed so inline from power it was:
power-->transistor-->solenoid-->ground
Arduino
and it did not work. So my question is why would this NOT work? I'm happy it works now of course, but would appreciate any insight since I can't come up with a reason why it didn't work in this configuration. Thanks!
dustynrobots
Re: Solenoid circuit question
by adafruit on Mon Dec 03, 2012 10:22 pm
a NPN transistor is on when the the base is about .7V above the emitter. if you connect the emitter to ground, then you can pull the base up to 0.7v. if the emitter is 'floating' or connected to an inductor (which, when turning on, is an instant short but then turns into an open) then the base wont be steady. thats the short answer, for more details, check horowitz & hill, chapter 1 & 2
