NFC breakout with Boarduino
by kemcelroy on Sun Dec 09, 2012 4:33 pm
NFC breakout board (PN532) and Boarduino
I am using the NFC PN532 Breakout Board with a Boarduino and an RGB LED panel. The LEDs work fine and run with code on the Boarduino, so I know those two components work. However, when running the Boarduino, it does not recognize that the NFC board is attached.
NFC chip and Boarduino soldered onto board
The NFC board works with my Arduino Uno, and I set it up with the Boarduino according to the same pin structure that worked on my Uno. I have attached these photos to show the pin set up and the next photo shows the soldering on the opposite side.
back of board
I have double and triple checked the wires to make sure they go to the right Boarduino pin and the right NFC board pin. Please let me know if you have any suggestions on what I should try next. Thanks!
kemcelroy
Re: NFC breakout with Boarduino
by adafruit_support_rick on Wed Dec 12, 2012 12:26 pm
Looks like you've got GND connected to pin 7 of the 4050 instead of pin 8?
