DHT11 versus DHT22
DHT11 versus DHT22
by bkenobi69 on Mon Jan 07, 2013 11:59 am
I have a few DHT11 sensors that I purchased last year. I have tested them with my Arduino to determine precision among the group. I found that there is noticeable variation from one sensor to the next in both temperature and humidity. I am considering upgrading these modules to a better sensor. Does anyone know if the DHT22 is better from one unit to the next in reporting the same values of temperature and humidity? I was originally looking at the SHT75, but I need 3 and the prices I was finding last year were pretty steep especially compared to the DHT11.
Background:
The goal of these sensors is to act as a set of sensors for an attic fan controller. I need to know the temperature and humidity of the attic and the outside air. If there is a delta from one sensor to the next, it will be very difficult to determine what the delta in my humidity and temperature readings are. I know the DHT11 is a bottom end sensor, but I was expecting the inaccuracy to be consistent from sensor to sensor in the same environment. If this is simply an offset, I could apply an offset in the code. If the error varies dramatically and it's not based on temperature/humidity then the sensor won't work.
bkenobi69
Re: DHT11 versus DHT22
by adafruit_support_bill on Mon Jan 07, 2013 12:53 pm
Variation between two sensors of the same type is not unusual. In practice, all sensors require calibration for maximum accuracy. Once calibrated ( it should just require an offset ), the DHT sensors should give you repeatable results.
by bkenobi69 on Mon Jan 07, 2013 1:01 pm
If that's the case, then I guess I should build a database of values for all sensors so I can determine offset values.
Oh, one other question. I just grabbed a few resistors for my pull-up resistors. 3 are the same, but the other . Were different values. Since this is a digital sensor, I assume the value of the pull-up resistor will not affect the readings from the sensor. Is that a good assumption?
bkenobi69
by arctic_eddie on Mon Jan 07, 2013 1:13 pm
I have a similar project using four of the DHT22 sensors to determine dew shield design for telescopes. Since it may not be practical to calibrate each sensor, I've decided to create a matching scheme. Each sensors is monitored in a sketch through a range of values in unison and under the same conditions. One is selected as the reference. It could be the one closest to the average value or one that is deemed to be the most accurate. You could also select the readings from an independent sensor that is judged accurate. The data from the reference and the others are entered as #define values for high and low readings in the range of interest. Next, the map() is re-written as fmap() by just changing the input values to float(). The fmap() function and the #define data are used in the application sketch to make each sensor look identical to the reference item. I'm now testing the sketch with a set of 10K epoxy thermistors. After I get my four DHT22's(out of stock), I'll post the sketch and procedure in this forum.
arctic_eddie
by adafruit_support_bill on Mon Jan 07, 2013 1:19 pm
Pull up value can vary a bit. Too low a value will be too strong of a pull up & the sensor won't be able to overcome it. Somewhere in the 4.7K-20K ohm range should be fine.
by bkenobi69 on Mon Jan 07, 2013 1:24 pm
So even the DHT22 has some variance from sensor to sensor? In that case, the only difference between the DHT11 and DHT22 is the accuracy and range specs. The DHT11 works for me as long as unit to unit is close, so I'll definitely need to generate calibration tables. Thanks for the input!
I'll check my resistors and replace if out of that range. Thanks!
bkenobi69
by adafruit_support_bill on Mon Jan 07, 2013 1:54 pm
All types of sensor have variance. If you buy enough of them you can test them all and hand-pick a matched set. But in practice, it is easier to just add the offset.
by bkenobi69 on Tue Jan 08, 2013 1:58 am
How long do sensors generally take to reach equilibrium? I've just tested all 6 of my sensors in 5 locations for up to 5 minutes per location. I didn't expect the sensors to react instantly, but I am a little taken aback by the fact that going from inside at ~68 degF to outside at ~50 degF the sensors didn't level out after 5 minutes. If I run the attic fan for 15 minutes to exhaust the air 2-3x, I don't know if the sensors would see a new humidity and be accurate. My goal was to run the fan for say 15 minutes per hour when the humidity delta is high enough and above a threshold. I don't know if these sensors will get me where I need to be with the delay. Perhaps moving air will allow the sensor to react quicker than stagnant air.
   DHT calibration
   DHT1   DHT2   DHT3   DHT4   DHT5   DHT6   DHT1   DHT2   DHT3   DHT4   DHT5   DHT6
Time   T   T   T   T   T   T   H   H   H   H   H   H
0   64.4   64.4   60.8   64.4   62.6   66.2   59   58   55   59   46   45
2   64.4   62.6   60.8   64.4   62.6   66.2   59   58   55   59   46   45
4   64.4   62.6   60.8   62.6   62.6   64.4   59   58   55   59   46   46
6   64.4   62.6   59   62.6   62.6   64.4   60   58   56   59   45   46
8   64.4   62.6   59   62.6   62.6   64.4   60   58   57   60   45   46
10   64.4   62.6   59   62.6   60.8   64.4   60   59   57   60   47   45
12   62.6   62.6   59   62.6   60.8   64.4   60   59   58   60   47   45
14   62.6   60.8   59   62.6   60.8   62.6   60   60   58   60   46   45
16   62.6   60.8   59   62.6   60.8   62.6   60   60   59   60   46   45
18   62.6   60.8   59   62.6   60.8   62.6   60   60   59   60   46   45
20   62.6   64.4   57.2   62.6   60.8   62.6   61   60   60   60   46   45
22   62.6   60.8   57.2   60.8   59   62.6   61   61   60   62   46   45
24   62.6   62.6   57.2   60.8   59   62.6   61   61   61   62   46   45
26   62.6   62.6   57.2   60.8   59   60.8   61   61   61   62   46   46
28   60.8   62.6   57.2   60.8   59   60.8   62   61   61   62   46   46
30   60.8   62.6   57.2   60.8   59   60.8   62   61   62   62   46   46
32   60.8   62.6   57.2   60.8   59   60.8   62   61   62   62   46   46
34   60.8   62.6   57.2   60.8   59   60.8   63   61   62   62   46   46
36   60.8   62.6   57.2   60.8   57.2   59   63   61   62   62   47   46
38   60.8   62.6   57.2   60.8   57.2   59   63   62   62   63   47   46
40   60.8   62.6   57.2   60.8   57.2   59   63   62   63   63   47   46
42   60.8   62.6   57.2   60.8   57.2   59   63   62   63   63   47   46
44   60.8   60.8   57.2   59   57.2   59   63   63   63   63   47   46
46   59   60.8   55.4   59   57.2   59   63   63   63   63   47   46
48   59   60.8   55.4   59   57.2   59   64   63   63   63   47   46
50   59   60.8   55.4   59   57.2   59   64   63   64   63   47   46
52   59   60.8   55.4   59   57.2   59   64   64   64   63   47   46
54   59   60.8   55.4   59   57.2   59   64   64   64   64   47   46
56   59   60.8   55.4   59   55.4   57.2   64   64   64   64   48   47
58   59   60.8   55.4   59   55.4   57.2   64   64   65   64   48   47
60   59   60.8   55.4   59   55.4   59   65   64   65   64   48   48
62   59   60.8   55.4   59   55.4   59   65   64   65   64   48   47
64   59   60.8   55.4   59   55.4   59   65   65   65   64   48   48
66   59   60.8   55.4   59   55.4   59   65   65   65   64   48   48
68   59   59   55.4   59   57.2   59   65   65   66   64   49   48
70   59   59   55.4   59   57.2   59   65   65   66   65   49   48
72   57.2   59   53.6   59   57.2   59   67   65   67   65   49   48
74   57.2   59   53.6   59   57.2   59   67   65   67   65   49   48
76   57.2   59   53.6   57.2   57.2   59   67   66   67   66   50   48
78   57.2   59   53.6   57.2   57.2   59   67   66   68   66   50   48
80   57.2   59   53.6   57.2   57.2   59   67   66   68   66   50   48
82   57.2   59   53.6   57.2   57.2   59   68   66   68   66   50   48
84   57.2   59   53.6   57.2   57.2   59   68   66   68   67   50   48
86   57.2   59   53.6   57.2   55.4   57.2   68   66   69   67   50   49
88   57.2   59   53.6   57.2   55.4   57.2   68   67   69   67   50   49
90   57.2   59   53.6   57.2   55.4   57.2   68   67   69   67   50   49
92   57.2   59   53.6   57.2   55.4   57.2   68   67   69   67   50   49
94   57.2   59   53.6   57.2   55.4   57.2   69   67   69   67   50   49
96   57.2   59   53.6   57.2   55.4   57.2   69   67   70   68   50   50
98   57.2   59   53.6   57.2   55.4   57.2   69   67   70   68   50   50
100   57.2   59   53.6   57.2   55.4   57.2   69   67   70   68   51   50
102   57.2   59   53.6   57.2   55.4   57.2   69   68   70   68   51   50
104   57.2   59   53.6   57.2   55.4   57.2   69   68   70   68   51   50
106   57.2   59   53.6   57.2   55.4   57.2   70   68   71   68   51   50
108   55.4   57.2   53.6   57.2   55.4   57.2   70   69   71   68   51   50
110   55.4   57.2   53.6   57.2   55.4   57.2   70   69   71   69   51   50
112   55.4   57.2   53.6   57.2   55.4   57.2   70   69   71   69   51   50
114   55.4   57.2   53.6   57.2   55.4   57.2   70   69   71   69   51   50
116   55.4   57.2   51.8   57.2   55.4   57.2   70   70   71   69   51   50
118   55.4   57.2   53.6   55.4   55.4   57.2   71   70   72   69   51   50
120   55.4   57.2   51.8   55.4   55.4   57.2   71   70   72   69   51   50
122   55.4   57.2   51.8   55.4   55.4   57.2   71   70   72   69   51   50
124   55.4   57.2   51.8   55.4   59   55.4   71   70   72   69   53   51
126   55.4   57.2   51.8   55.4   53.6   55.4   71   70   72   70   52   51
128   55.4   57.2   51.8   55.4   59   55.4   71   70   73   70   53   51
130   55.4   57.2   51.8   55.4   59   55.4   72   70   73   70   53   51
132   55.4   57.2   51.8   55.4   59   55.4   72   71   73   70   53   51
134   55.4   57.2   51.8   55.4   59   55.4   72   71   73   70   53   51
136   55.4   57.2   51.8   55.4   59   55.4   72   71   73   70   53   51
138   55.4   57.2   51.8   55.4   59   55.4   72   71   73   70   53   51
140   55.4   57.2   51.8   55.4   59   55.4   72   71   74   70   53   51
142   55.4   57.2   51.8   55.4   57.2   55.4   73   71   74   70   54   51
144   55.4   57.2   51.8   55.4   57.2   55.4   73   71   74   71   54   52
146   55.4   57.2   51.8   55.4   57.2   55.4   73   71   74   71   54   51
148   55.4   57.2   51.8   55.4   57.2   55.4   73   71   74   71   54   52
150   55.4   57.2   51.8   55.4   57.2   55.4   73   72   74   71   54   52
152   53.6   57.2   51.8   55.4   57.2   55.4   74   72   74   71   54   52
154   53.6   57.2   51.8   55.4   57.2   55.4   74   72   75   71   54   52
156   53.6   57.2   51.8   55.4   57.2   55.4   74   72   75   71   55   52
158   53.6   57.2   51.8   55.4   57.2   55.4   75   72   75   72   55   52
160   53.6   57.2   51.8   55.4   57.2   55.4   75   72   75   72   55   52
162   53.6   57.2   51.8   55.4   57.2   55.4   75   72   75   72   55   52
164   53.6   57.2   51.8   55.4   57.2   55.4   75   72   75   72   55   52
166   53.6   57.2   51.8   55.4   57.2   55.4   75   73   75   72   55   52
168   53.6   55.4   51.8   55.4   57.2   55.4   75   73   75   72   55   53
170   53.6   57.2   51.8   55.4   57.2   55.4   75   73   76   72   55   52
172   53.6   55.4   51.8   55.4   57.2   55.4   75   73   76   72   55   53
174   53.6   55.4   51.8   55.4   57.2   55.4   75   73   76   72   55   53
176   53.6   55.4   51.8   55.4   57.2   55.4   76   73   76   72   55   53
178   53.6   55.4   51.8   55.4   57.2   55.4   76   73   76   72   55   53
180   53.6   55.4   51.8   55.4   57.2   55.4   76   73   76   73   55   53
182   53.6   55.4   51.8   55.4   57.2   55.4   76   73   76   73   55   53
184   53.6   55.4   51.8   55.4   57.2   55.4   76   73   76   73   55   53
188   53.6   55.4   51.8   55.4   57.2   55.4   76   74   76   73   55   53
190   53.6   55.4   51.8   55.4   57.2   55.4   76   74   76   73   55   53
192   53.6   55.4   51.8   55.4   57.2   55.4   76   74   76   73   55   53
194   53.6   55.4   51.8   55.4   57.2   55.4   77   74   77   73   56   54
196   53.6   55.4   51.8   55.4   57.2   55.4   77   74   77   73   56   54
198   53.6   55.4   51.8   55.4   57.2   55.4   77   74   77   74   56   54
200   53.6   55.4   51.8   55.4   57.2   55.4   77   74   77   74   56   54
202   53.6   55.4   50   55.4   57.2   55.4   77   74   78   74   56   54
204   53.6   55.4   51.8   55.4   57.2   55.4   77   74   77   74   56   54
206   53.6   55.4   50   55.4   57.2   53.6   77   74   78   74   56   55
208   53.6   55.4   50   53.6   57.2   55.4   77   74   78   75   56   54
210   53.6   55.4   50   53.6   55.4   53.6   77   74   78   75   56   55
212   53.6   55.4   50   55.4   55.4   53.6   77   75   78   74   56   55
214   53.6   55.4   50   53.6   55.4   53.6   77   75   79   75   56   55
216   53.6   55.4   50   53.6   55.4   53.6   77   75   79   75   56   55
218   53.6   55.4   50   53.6   55.4   53.6   77   75   79   75   56   56
220   53.6   55.4   50   53.6   55.4   53.6   77   75   79   75   56   56
222   53.6   55.4   50   53.6   55.4   53.6   78   75   79   75   56   56
224   53.6   55.4   50   53.6   55.4   53.6   78   75   79   76   57   56
226   51.8   55.4   50   53.6   55.4   53.6   78   75   79   76   56   56
228   51.8   55.4   50   53.6   55.4   53.6   78   75   79   76   57   56
230   51.8   55.4   50   53.6   55.4   53.6   78   75   79   76   57   56
232   53.6   55.4   50   53.6   55.4   53.6   78   75   79   76   57   56
234   51.8   55.4   50   53.6   55.4   53.6   78   75   79   76   57   56
236   51.8   55.4   50   53.6   55.4   53.6   78   76   79   76   57   56
238   51.8   55.4   50   53.6   55.4   53.6   78   76   80   76   57   56
240   51.8   55.4   50   53.6   55.4   53.6   78   76   80   76   57   56
242   51.8   55.4   50   53.6   55.4   53.6   78   76   80   76   57   56
244   51.8   55.4   50   53.6   55.4   53.6   79   76   80   76   57   57
246   51.8   55.4   50   53.6   55.4   53.6   79   76   80   77   58   57
248   51.8   55.4   50   53.6   55.4   53.6   79   76   80   77   58   57
250   51.8   55.4   50   53.6   55.4   53.6   79   76   80   77   58   57
252   51.8   55.4   50   53.6   55.4   53.6   79   76   80   77   58   57
254   51.8   55.4   50   53.6   55.4   53.6   79   76   80   77   58   57
256   51.8   55.4   50   53.6   55.4   53.6   79   76   80   77   58   57
258   51.8   55.4   50   53.6   55.4   53.6   79   76   80   77   58   57
260   51.8   53.6   50   53.6   55.4   53.6   79   77   80   77   58   57
262   51.8   53.6   50   53.6   55.4   53.6   79   77   80   77   59   57
264   51.8   53.6   50   53.6   55.4   53.6   79   77   80   77   59   58
266   51.8   53.6   50   53.6   55.4   53.6   79   77   80   77   60   58
268   51.8   53.6   50   53.6   55.4   53.6   79   78   80   77   60   58
270   51.8   53.6   50   53.6   55.4   53.6   79   78   81   77   60   58
272   51.8   53.6   50   53.6   55.4   53.6   79   78   81   78   60   58
274   51.8   53.6   50   53.6   55.4   53.6   79   78   81   78   60   58
276   51.8   53.6   50   53.6   55.4   53.6   79   78   81   78   60   58
278   51.8   53.6   50   53.6   55.4   53.6   80   78   81   78   60   58
280   51.8   53.6   50   53.6   55.4   53.6   80   78   81   78   61   59
282   51.8   53.6   50   53.6   55.4   53.6   80   78   81   78   61   59
284   51.8   53.6   50   53.6   55.4   53.6   80   78   81   78   61   59
286   51.8   53.6   50   53.6   55.4   53.6   80   78   81   78   62   59
288   51.8   53.6   50   53.6   55.4   53.6   80   78   81   78   62   59
290   51.8   53.6   50   53.6   55.4   53.6   80   78   81   78   62   59
292   51.8   53.6   50   53.6   55.4   53.6   80   79   81   78   62   59
294   51.8   53.6   50   53.6   55.4   53.6   80   79   81   79   62   60
296   51.8   53.6   50   53.6   55.4   53.6   80   79   81   79   62   60
298   51.8   53.6   50   53.6   55.4   53.6   80   79   81   79   62   60
300   51.8   53.6   50   53.6   55.4   53.6   80   79   81   79   63   61
302   51.8   53.6   50   53.6   55.4   53.6   80   79   81   79   63   61
bkenobi69
by adafruit_support_bill on Tue Jan 08, 2013 7:19 am
Temperature sensor reaction time is largely related to the thermal mass of the sensor and whatever it is attached to. Air flow will improve the thermal transfer to the surrounding air. The DHTs are rather 'chunky' as temperature sensors go. But I haven't done any in-depth testing on reaction times with them.
by bkenobi69 on Tue Jan 08, 2013 11:50 am
I'll rerun my calibration test with a fan blowing over the sensors. In practice, the sensor would likely be installed in a location where the attic fan would draw flow across it anyway, so this would be a good check.
bkenobi69
by jonesjimbo on Sat Jan 19, 2013 10:54 am
bkenobi,
I have several DHT11 sensors that I am trying to use but have been having trouble figuring out how to modify the code to poll multiple sensors.
Would you be willing to share your code for this?
Jim
jonesjimbo
by adafruit_support_bill on Sat Jan 19, 2013 11:24 am
Just declare one for each sensor and give them different names:
DHT_1 dht(2, DHT11);
DHT_2 dht(3, DHT11);
DHT_3 dht(4, DHT11);
DHT_4 dht(5, DHT11);
Then you can read from them by name:
  float h_1 = dht_1.readHumidity();
  float t_1 = dht_1.readTemperature();
  float h_2 = dht_2.readHumidity();
  float t_2 = dht_2.readTemperature();
  float h_3 = dht_3.readHumidity();
  float t_3 = dht_3.readTemperature();
  etc...
by jonesjimbo on Sat Jan 19, 2013 11:33 am
Thanks for the quick response!
So does that mean I should leave out:
"#define DHTPIN 2"
which is in the example on github?
Jim
jonesjimbo
by adafruit_support_bill on Sat Jan 19, 2013 11:45 am
Yes. Instead of passing DHTPIN in the constructor, use the actual pin number for that sensor.
by bkenobi69 on Sat Jan 19, 2013 2:59 pm
In my code I just created DHTPIN1, DHTPIN2, etc.
I reran a couple more scenarios using the fan. One was sitting inside with the fan blowing across the sensors. I wanted to make sure that the fan wouldn't create funny results which it did not. Next, I put the fan, arduino, sensors and laptop outside for a few minutes. I forgot to bring the data with me and now I'm out of town. I can say that the laptop was covered in condensation and at least one reading indicated 95%.
I am planning on writing some code that will run once at power up that will calibrate all used sensors automatically. I believe I have come up with an approach and will poat it here when I finish.
bkenobi69
