FTDI Friend Not Detected When Plugged In
by b34npour on Thu Jan 17, 2013 1:18 am
I just received an FTDI Friend from Adafruit, and when I plug it in via USB it doesn't show up in my terminal when I type "ls /dev/cu.*". The only two things that show up are "/dev/cu.Bluetooth-Modem" and "/dev/cu.Bluetooth-PDA-Sync". I'm on a mac (obviously).
I've tried three different USB cables with the same result. Any ideas as to what I might be doing wrong?
b34npour
Re: FTDI Friend Not Detected When Plugged In
by adafruit_support_bill on Thu Jan 17, 2013 7:27 am
Have you tried different USB ports as well? If you are running Parallels, check to see if it is getting picked up by Parallels instead of MacOS.
by b34npour on Thu Jan 17, 2013 1:52 pm
I made a stupid mistake; the driver wasn't installed. Works fine now, thanks!
b34npour
